세은 김
Mar 24, 2026 10:54 PM UTC
pigma 파일을 열시 편집기를 열때 오류가 발생하였습니다. 발생되면 파일이 열리지않습니다.
네트워크는 정상적으로 연결되어있는 상태인데도 계속 해당 오류가 발생되면서 열수 없는데 해결 방법이 있을까요 ?
연결 오류: -106
컴퓨터가 오프라인 상태이거나 Figma 서버에 문제가 있을 수 있습니다.
Figma가 자동으로 다시 연결을 시도합니다.
Mar 25, 2026 4:43 AM UTC
Hi ​@세은 김,
I hope it’s OK to reply in English.
I understand you’re seeing “Connection error: -106” which is preventing you from opening your file.
This error typically indicates a network setting that’s blocking Figma from connecting to required resources — most often a firewall, proxy, or VPN.
Please try the steps below to help resolve the issue:
  1. Try a different network (another Wi-Fi or a mobile hotspot). This helps determine whether the issue is specific to your network. Please check: Adjust your network settings
  2. Does this happen in the browser, the desktop app, or both?
    If you’re using the Figma desktop app on a work-managed computer, ask your IT team whether any network settings are blocking Port 443. See: Connection or server error 403
  3. Disable extensions (especially ad blockers) temporarily, as they can interfere with connections.
  4. Flush your DNS and restart your browser
  5. Clear the Figma desktop app cache (and your browser cache). Instructions: Clear the Figma desktop app cache
If you’ve tried all of the above and still see the error, I’ll send you a DM shortly with next steps so we can investigate further.
