Camille Hitchen
Nov 16, 2026 10:51 AM UTC
Permissions: Why can ONLY FILE OWNERS change ACCESS SETTINGS ?
On newly created Figma presentation files, it appears that only the file owner has permission to change the access settings when sharing published presentation links.
Other team members with editing access are unable to access or amend the sharing settings to change the audience drop down from 'Our team' to 'Anyone'.
Interestingly, this does not appear to affect older presentation files, where anyone with editing access can still amend the access permissions as expected.
Has there been a recent change or update to Figma's sharing permissions? If so, could you please clarify whether this is intentional behaviour or a technical issue, and advise how we can restore the ability for all team members with editing access to manage sharing settings?
Thanks
Gayani_S
Nov 16, 2026 11:11 AM UTC
Hey ​@Camille Hitchen, thanks for reaching out!
I’d like to understand a bit more before I say whether this is intended or a technical issue.
The most recent public change is Updates to Figma’s file management, which covers Projects becoming folders and simplified folder permissions. There was no change to who can edit the share settings on a file.
Only owners and people with Can edit permissions on a file can change that file’s permissions, and admins can also change permissions on files they already have access to. In the share modal, the audience access row at the top controls who can reach the file across your plan. The rows below it show people who were invited directly, or whose access is inherited from a folder.
To help me narrow this down, could you ask one of your teammates to open Share on one of the new files and on an older file in the same location, and let me know what looks different between the two, for example whether the audience access row can be selected and whether they’re listed by name?
Once I have that, I can point you in the right direction. If you’d rather send the file link, you can do that through the Support Hub so our customer support team can take look at the file’s permissions with you.
You can find more detail in File and folder permissions and Share files and prototypes.
Let me know what you find, thank you!
Camille Hitchen
Nov 16, 2026 11:24 AM UTC
Yes we tried this already and they looked the same - the only difference being that in the new file, the ‘anyone in newsubstance’ setting can’t be clicked.
Everyone is a team member and within ‘NEWSUBSTANCE’ so no one is usually invited directly to a file so that wouldn’t be the issue.
For context, I am admin and the screenshots are from my colleague who isn’t admin. As a test, I asked her to make a new file and I was unable to access the share settings even though I had edit access (and admin control).
Gayani_S
Nov 17, 2026 5:13 PM UTC
Thanks for sharing those screenshots!
I can’t tell from here why that row can’t be selected on the newer files, so I’d like our customer support team to look at the file permissions directly. Could you send the link to one new file and one older file through the Support hub, and note which is which? That way we can compare the two side by side.
You can find more detail in File and folder permissions.
