EricaRW
Aug 7, 2025 11:27 AM UTC
PDF Export Missing Elements
Hello,
Figma exports some PDF without a lot of elemets, They all  are nested in the frame. They all visible in the preview in the windows browser but not visible in the PDF doc. In all PDF viewer/reader. I did all  - exported one by one, cleaned cache, restarted PC, but it still not visible.
UPD -- FOUND workaround! Ony one color elements were not visible.  I slightly changed it and it worked)))
Gayani_S
Aug 8, 2025 12:21 PM UTC
Hi ​@EricaRW, glad to hear you found a workaround!
If you’re open to it, could you share exactly what you changed with the color to fix the issue? It could be a huge help to other community members who might run into the same problem in the future.
Thanks for taking the time to update us!
Metro
Aug 18, 2025 8:10 PM UTC
Hello,
I think I had a similar issue and found a workaround as well.
In case it helps someone out here…
I designed some documents that had a background image on the wrapping frame.
When exporting as PDF, the image would disappear most of the time.
I tried a lot of things like clip content, making sure the image was a layer and not just a fill on my frame, etc.
The only fix I found was applying a uniform layer blur effect on my image, setting it to the lowest I could, which is 0.01.
The blur effect actually doesn’t do anything as the value is extremely low (at least I didn’t notice any change to the image).
After that, all my exports were correctly displaying the image as background.
