Feb 11, 2026 10:57 AM UTC
Pattern fill not working anymore
When clicking on an element and trying to set the fill to a pattern, it’s not possible to select a source and use it as a pattern anymore.
Issue is happening both in browser and desktop app (126.1.2).
    Junko3Solution
    Feb 12, 2026 7:37 AM UTC
    Hi ​@Dominik Eibensteiner,
    I understand that you’re experiencing an issue using patterns as a fill.
    I don’t have version 126.1.2 yet, but I tested on my side using the Figma Desktop app (126.0.4) and Chrome, and it’s working as expected.
    I also checked internally and saw some feedback that the “Select source” button can be a bit confusing for some users.
    Just to cover the basics, could you please confirm that you’re following the steps below to apply a Pattern fill?
    1. Select a layer on the canvas.
    2. Click the swatch in the Fill section of the right sidebar to open the color picker.
    3. Select  Pattern from the fill options.
    4. Click “Select source”, then select another object on the canvas.
    5. Use the pattern options to set the tile type, scale, spacing, alignment, and opacity.
    You can also refer to this guide (including a video walkthrough):Use patterns as a fill or stroke
    If the issue persists, could you please share a bit more detail?
    • When you click “Select source”, then choose another object, do you see any error message?
    • Does force-quitting and restarting the Figma Desktop app make any difference?
    • Is this happening in both the Desktop app and browser?
    • Is the issue limited to a specific file, or does it occur across all files?
    If you’re still experiencing the issue after trying the steps above:
    Please let us know the details. We’ll connect you with our team to investigate further or you can submit a bug report through Contact support via the (?) icon in the bottom-right corner of your Figma file.
    The chatbot will guide you through opening a report with our team so they can take a closer look, and you’ll be able to communicate with them directly.
    Here’s a guide you can refer to:  What to share in a bug report to Figma Support
    Junko3Solution
    Ross2POINT
    Feb 18, 2026 4:40 PM UTC
    Since the latest Figma update, I’m unable to apply an image/pattern fill to shapes.
    When I set the Fill type to pattern fill and click “select source”, the file picker dialog does not open. Drag-and-drop into the Fill well also doesn’t work.
    This is happening in the Figma Desktop app on macOS 15.7.3.
    Is anyone else experiencing this? Any known fixes?
    Curt Estridge
    Mar 25, 2026 2:04 PM UTC
    Im still having the same issue. The “Select Source” button doesn't work when using the patterns feature.
    Desktop app 126.2.9
    Mac OS 26.3.1
    Peter5
    Apr 29, 2026 8:24 AM UTC
    I’m also encountering the same error.
