Bao Do
Jun 19, 2026 3:22 AM UTC
Pasting image into a fill property doesn't work
I copy a frame as an image and try to paste that image into a fill image property of another frame but this doesn’t work anymore. Even copy image from other source (from the browser, from computer) isn’t working too. I’m using Figma app on Windows
    Gayani_S
    Jun 19, 2026 10:34 AM UTC
    Hey ​@Bao Do, thanks for reaching out!
    Sorry to hear you're running into this, let's figure out what's going on. A few things that would help us narrow this down:
    Could you let us know which version of the Figma app you're on? You can find this under Help → Figma desktop app info (or About Figma in the browser). Also, are you seeing this happen in both the desktop app and the browser, or just one of them?
    In the meantime, here's something worth trying: rather than pasting while the fill picker is open, try clicking on the fill thumbnail in the right sidebar first (the image icon to the left of the fill swatch — it'll highlight in blue when selected), then paste with Ctrl+V. A few users have found this more reliable than pasting while the picker panel is open.
    You can also use Upload from computer directly in the fill picker as a fallback, the steps are covered in Add images and videos to designs if you haven't tried that route yet.
    Let me know what you find and we'll go from there!
    laptopgiant
    Jun 19, 2026 10:41 AM UTC
    If you're running into the issue where pasting an image into a Figma fill property doesn't work, you're definitely not the only one. Several users have reported the same behavior, and it appears to be related to recent updates. A quick refresh or selecting the image fill itself before copying can often solve the problem until the latest fixes are applied. Discussions like these are why communities matter, and Laptop Giant always enjoys following practical design tips that improve everyday workflows.
    Bao Do
    Bao DoAuthor
    Jun 19, 2026 11:19 AM UTC
    Desktop app version 126.5.6 (on Windows 11). I tried on the browser and the issue still happen. I can copy and paste image fill no problem, but I can’t no longer paste an image (no matter what the source of this image) into a fill to create image fill. I did find a work around now, by pasting the image straight to the canvas and copy its image fill to paste to other frames, it definitely a slow down but nothing too critical.
    The reason I need this to work is that I often have a complex background create in Figma and don’t want to duplicate it too many time, so I make an “image” of that frame (copy as png) to use as a image fill for a container, so I don’t need a separate complex layer for background.
    Gayani_S
    Jun 22, 2026 12:52 PM UTC
    Hey ​@Bao Do, thanks again for all that detail!
    I've gone ahead and created a support ticket for you so our team can dig into this properly. You should receive an email shortly, when you do, please reply and include as many details as you can (any additional screenshots, file links, or steps you've noticed). Someone will follow up with you there directly.
    For reference, your ticket number is #1974855.
    In the meantime, the step-around you found, pasting the image to the canvas first and copying its image fill across to your target frames, is the most reliable path for now.
    Someone from the team should be in touch with you soon, appreciate your patience in the meantime!
    Anon Designer
    Aug 6, 2026 3:36 PM UTC
    Encountering a similar issue. Previously, there was a reliable workflow for copying an image fill property from one frame to another:
    1. Select the source frame
    2. In the Fill panel (right sidebar), click the image layer inside the fill block
    3. Press `Cmd + C` to copy
    4. Select the target frame
    5. Press `Cmd + V` to paste
    Expected Behavior: Just the image fill property should be transferred to the target frame.
    Actual Behavior: The paste action applies the image fill to the target frame but also includes other properties such as corner radius.
    If this is a known issue, I'd appreciate any updates on when it might be fixed.
    Gayani_S
    Aug 7, 2026 2:14 PM UTC
    Hey ​@Anon Designer, thanks for the clear repro steps!
    The method you tried (selecting the image layer in the Fill section of the right sidebar, then copying and pasting onto the target frame) is actually the way we'd recommend today for swapping just the image fill without touching anything else. So having other properties like corner radius carry over with it isn't what's supposed to happen.
    There have been some other reports earlier in this thread about copying and pasting image fills too, but I want to check with our team on whether this specific corner radius behaviour is connected or something separate before I call it a confirmed issue. I don't want to point you in the wrong direction.
    Could you let me know which Figma app version you're on (Help → Figma desktop app info, or About Figma in the browser), and whether you're seeing this in the desktop app, the browser, or both? That'll help the team narrow it down.
    I'm going to get this logged with our team so they can take a closer look at the specifics, a quick screen recording of it happening (if you're able to grab one) would help speed things along.
    In the meantime, here's our Copy and paste objects article if you want to double check the steps you're using.
    Thanks again for the detail here!
    Anon Designer
    Aug 7, 2026 4:00 PM UTC
    Thanks for looking into this! I've attached a screen recording that captures the issue happening.
    Here are the details you asked for:
    • Desktop app version: 126.7.10
    • In both desktop app and browser I am experiencing the same behavior.
    • I've double-checked against the tutorial steps and I believe I'm following them correctly. You can see in the video the corner radius is being carried over.
    Hopefully the video helps make it clearer. 😊
    Gayani_S
    Aug 14, 2026 3:28 PM UTC
    Hey @Anon Designer, apologies for the delayed response and thanks so much for the recording!
    Your source frame has a 64px corner radius and an image fill, and the target frame starts at 0 corner radius with a plain white fill. After copying the fill from the source and pasting it onto the target, the fill updates correctly to the image. But the corner radius also flips to match the source's 64px, which shouldn't happen with this method.
    I've passed the video and these specifics along to our engineering team so they have everything they need to dig in. I don't have a timeline to share yet, but I'll keep this thread updated as soon as I hear more.
    In the meantime, the method mentioned earlier in this thread, pasting the image to the canvas first, then copying its image fill across has worked as a fallback for other users on the image side of things. If the corner radius carries over there too, let us know and we'll look at that separately.
    Thanks again, this level of detail really helps speed things up on our end!
    Anon Designer
    Aug 14, 2026 4:39 PM UTC
    Your understanding is correct!
    Thanks so much for looking into this! It's very much appreciated. 😊
    Gayani_S
    Aug 18, 2026 5:45 AM UTC
    Hey ​@Anon Designer, I've been going back and forth with our engineering team on this, and there's one distinction worth double-checking before we go further. Figma Design actually has two separate paste actions that look similar but behave very differently:
    • ⌘C / Ctrl+C on a highlighted property (like the Fill row you clicked) copies just that one property
    • ⌥⌘C / Ctrl+Alt+C ("Copy properties") copies everything the layer supports. Corner radius included, and pastes with ⌥⌘V / Ctrl+Alt+V
    Since corner radius is carrying over for you, I want to rule out whether the second shortcut is getting triggered somewhere in the flow. Could you try it again making sure it's the plain ⌘C / ⌘V (no Option) on both the copy and paste steps, and let me know if the corner radius still carries over?
    You can see both methods laid out side by side in our Copy and paste properties between layers article if useful.
    Thanks again for helping us narrow this down!
