Mari G
Jun 19, 2025 12:12 PM UTC
Paste and Copy don’t work when clicked (for string variables)
One more strange thing: the Paste and Copy actions don’t work when clicked — only via shortcuts (for string variables)
    Jun 19, 2025 1:08 PM UTC
    Hey ​@Mari G ,
    Thanks for flagging it! I tried to reproduce it, and it’s working on my end.
    Does this only seem to happen with a specific string copied or it happens with any string you paste in the variable modes?
    As a temporary solution, please try and clear out your cache in the browser and Desktop app. Then, force quit and restart Figma and check if this helps.
    You can clear the desktop app cache on a Mac in the Help menu under Troubleshooting. If you'd prefer to manually clear your cache you can:
    1. Quit the Figma desktop app
    2. Open Terminal.app and enter the following command: rm -rf "$HOME/Library/Application Support/Figma"
    3. Try opening the desktop app again
    You can clear the desktop app cache on Windows under the toggle-arrow at the right of the top toolbar under Help > Troubleshooting. If you'd prefer to manually clear your cache you can:
    1. Close the Figma desktop app
    2. Open the Start menu, and paste in this, followed by enter: %APPDATA%\Figma
    3. In the window that opens, delete the Desktop and DesktopProfile folders if they exist
    4. Launch the desktop app again
    If you are still seeing the issue after clearing you cache, I’d recommend you to reach out directly to the support team: Submit a bug report
    Please use your Figma email account, mention the steps you have done and provide a link of the affected file, and invite support-share@figma.com with "can edit" permission (from the file's share settings) so the support team can look into this further. This will not count towards your billing at all. Thank you!
    Ruth2
    Aug 14, 2025 6:16 AM UTC
    I am having the same problem across all the variables. I followed the instructions above and still every time I try to copy and paste my variable code (as I used to do), the code is not copied and pasted, but the element itself is pasted instead. 😭
    Aug 28, 2025 10:38 AM UTC
    Hey ​@Ruth2 , sorry to hear the issue is still persisting even after following the steps!
    At this point, I’d recommend reaching out directly to our support team here: Submit a bug report
    They’ll be able to investigate further and guide you on the next steps 🙏🏼
