David60
Feb 7, 2025 2:37 PM UTC
Overrided color of nested component deleted/reseted when switching variant with variables ?
Hi,
the color of my nested component was reset when I using variable to change this component variant.
My component :
I override the color​​ in the instance and change manualy the variant  → Overrided color was keeped
I used attach the variant name to my variables → Overrided color was keeped
I nested Component 1 to a second Component 2. Changed manually the variant →  Overrided color was keeped
I used variable to automaticely change variant → Overrided color reseted !
There are a soluion to keep the overried colors ?
    treasure
    Feb 7, 2025 10:58 PM UTC
    +1 to also having this issue, our team expert is also stumped since sometimes it works but when we nest another component instance the variable we set also resets the properties
    Feb 13, 2025 5:19 AM UTC
    Hi ​@David60 ​@treasure ,
    Thanks for reaching out. I hope I can check the setting, so would you be able to share the file link with access to support-share@figma.com? It won't affect your billing. I hope I can investigate it further.
    Toku
    David60
    David60Author
    Feb 13, 2025 1:06 PM UTC
    Toku
    Thx, I send you all informations in a PM
    David60
    David60Author
    Feb 24, 2025 10:17 AM UTC
    Hi ​@y_toku have you investigated and reproduce the bug ?
