Anna Ardysheva
Jun 21, 2026 3:47 PM UTC
Option+Command+V is not working
Hi Figma Support,
After the recent update, Paste properties stopped working correctly in Figma Desktop.
Copy properties still works: when I press Option + Command + C, Figma shows the “Copied properties” notification. However, Paste properties does not apply the copied formatting when I press Option + Command + V.
This is especially problematic when editing text fragments inside a text layer. I use this feature constantly to apply font formatting to selected characters, for example numbers and mathematical symbols inside longer text blocks. Before the update, the same shortcut and workflow worked normally.
Steps to reproduce:
  1. Open a text layer in Figma Desktop.
  2. Select a formatted part of the text.
  3. Press Option + Command + C.
  4. Select another part of the same or another text layer.
  5. Press Option + Command + V.
  6. The copied text properties are not applied.
I have already tried restarting Figma and using Reset Figma and Restart, but the issue remains.
Could you please check if this is a bug in the latest Figma Desktop update?
Thank you.
    Celine_Solution
    Jul 8, 2026 9:34 AM UTC
    Hi everyone, Celine from Figma here, working closely with ​@Tom Reem !
    Just giving you an update: our engineers have released and verified a fix for copying and pasting as a property within the same file. For cross-file copy and paste, the fix is available now. Please restart/refresh Figma to ensure you're using the latest release.
    Thank you!
    Gayani_S
    Jun 22, 2026 12:18 PM UTC
    Hey ​@Anna Ardysheva, thanks for reaching out!
    To help narrow things down, a couple of questions:
    1. What version of Figma Desktop are you on? You can check under the Figma menu > Help and account > About Figma.
    2. Does the same issue happen in the browser version of Figma?
    In the meantime, a couple of things worth trying:
    1. Try the menu path instead of the shortcut: right-click a layer and select Copy/paste as > Paste properties. This helps confirm whether it's the shortcut binding or the underlying action that's affected.
    2. Check whether another app on your system has claimed Opt + Cmd + V as a global shortcut, clipboard managers, communication tools, and some accessibility apps can intercept these silently.
    3. If the shortcut continues to be unresponsive, you can also reassign it temporarily via macOS System Settings > Keyboard > Keyboard Shortcuts > App Shortcuts, add Figma and set "Paste Properties" to a different key combination while we dig into this.
    For reference on how Paste properties is expected to work with text selections, our Copy and paste properties between layers article has a good overview.
    Once you share those details, I can take it from there!
    Ryan8
    Jun 23, 2026 4:25 PM UTC
    Hi ​@Gayani_S I am having this issue as well. I believe the underlying action is affected. `Paste properties` notification or effect does not happen on any of the below:
    • Shortcut: Opt + Cmd + V
    • Menu path: Copy/Paste as… → `Paste properties`
    • Macro modal: Cmd + / → type `Paste properties` → Hit `Enter`
    Jaycee Lewis
    Jun 23, 2026 9:19 PM UTC
    Hey ​@Ryan8 👋 Thanks for the follow up. I’d like to get this on to support. Along with what you already provided, would you be able to share the following:
    • What version of Figma Desktop are you on? You can check under the Figma menu > Help and account > About Figma
    • Does the same issue happen in the browser version of Figma?
    • Can you share a not-zoomed in screen-recording of the issue happening? This is always very useful for support (if there are privacy issues, this can be shared as an attachment in a support ticket)
    If so, I’ll open a support ticket for us. Talk soon! — Jaycee
    Ryan8
    Jun 24, 2026 3:29 AM UTC
    ​@Jaycee Lewis
    I was able to refine the reproduction steps for the error. A text box with multiple text styles in it cannot contain a source for copied properties, even if a specific word in that is highlighted as a source for those copied properties.
    Reproduction steps
    1. Make a text box with some text in it.
    2. Make one word bold.
    3. Select that word. Copy properties.
    4. Try to paste the properties onto a non-bold word in that text box.
    Answers to your questions
    • Figma Desktop App version 126.6.9
    • Yes
    • Screen recording attached, with Keyboard Viewer visible. I am showing 3 different methods failing: keyboard shortcuts, menu path, and macros. Successful cases as well as unsuccessful as described above.
    Pablo_Marfa
    Jun 24, 2026 9:30 AM UTC
    I am also having this exact same issue.
    My desktop version is also 126.6.9
    Jaycee Lewis
    Jun 24, 2026 11:19 PM UTC
    Hey ​@Ryan8 👋 Thank you for the assist. I opened a support ticket for us (ID 1981032) The subject line is — Paste properties not applying from mixed-style text source — all invocation methods. Please keep any eye on your email inbox for any replies and follow ups from support. Have an awesome rest of your week! — Jaycee
    Adam Banaszek
    Jul 3, 2026 1:40 PM UTC
    Same problem here. Font properties are not copied. I think it copies only line height.
    In browser and in desktop version 126.4.11
    Pablo_Marfa
    Jul 4, 2026 6:26 PM UTC
    Hi guys, it’s been two weeks already (update in between included) and the issue hasn’t been fixed yet. Could you look into this? Thank you.
    Tom Reem
    Jul 5, 2026 9:19 PM UTC
    Hey ​@Adam Banaszek and ​@Pablo_Marfa, thanks for checking back in. I've been in touch with our Technical Quality team and they're prioritizing this. We'll follow up here as soon as there's an update.
    Celine_Solution
    Thank you!
