keeeel
Aug 12, 2026 1:04 AM UTC
Odd Ctrl + Click behavior when trying to open layer menu
When I try to right click (ctrl + click) on a layer on my Mac, it doesn’t open the default layer menu. It usually works again on second attempt. I have the “ctrl + click opens right click menus” option enabled.
Interaction I am seeing when I ctrl + click:
Expected interaction:
    adamsmasher
    adamsmasherSolution
    Aug 26, 2026 6:59 PM UTC
    Hey again, ​@keeeel! We released a fix for this, so CTRL-click on a layer should just open up the right-click menu right away. Be sure to update the desktop app to the newest version, clear browser cache, reload, etc, and let me know if you still have trouble.
    Cheers!
    adamsmasher
    Aug 12, 2026 6:57 PM UTC
    Hey, ​@keeeel! Thanks so much for your post and for the video - I can understand your confusion here.
    This is actually the expected behavior when you have the Ctrl + click opens right click menu option enabled. The first click opens that setting’s own menu, and then the next time opens the actual context menu. As you’d expect, disabling the setting will get you the behavior you were expecting. Let me know if disabling the option doesn’t alter this behavior, or if you have other questions!
    keeeel
    keeeelAuthor
    Aug 12, 2026 8:30 PM UTC
    Hi ​@adamsmasher, appreciate your reply-- I was actually seeing this behavior with the menu option turned off and on. I’ll continue testing.
    keeeel
    keeeelAuthor
    Aug 13, 2026 6:07 PM UTC
    ​@adamsmasher I’ve confirmed that this behavior occurs if the layer is already selected (video attached). Is that expected?
    Ctrl + Click on unselected layer = opens context menu
    Ctrl + Click on selected layer = opens alternate menu
    adamsmasher
    Aug 13, 2026 7:33 PM UTC
    Thanks for the video! That’s expected, albeit also unexpected - I would expect the first click to open the contextual menu, but it actually deselects the layer which then makes the next CTRL-click work as you’d expect. I’m asking our team about this to see what is expected here - I’ll post back once I’ve got info to share.
    keeeel
    keeeelAuthor
    Aug 13, 2026 8:11 PM UTC
    Amazing, thank you! I believe I started seeing this behavior around 1-2 months ago.
    adamsmasher
    adamsmasherSolution
    Cheers!
