meet
Aug 3, 2026 12:31 PM UTC
Not able to apply mutiple preset to one path
Is it possible to apply multiple presets to one path in motion? I tried applying "Draw" & "Erase" but only one works. Can anyone help?
djvSolution
Aug 3, 2026 8:18 PM UTC
Hi ​@meet, thanks for reaching out!
You can only apply one path preset (like Draw or Erase) per object, and path presets only work on open paths. If you apply a second one, it won't stack with the first. A couple of quick questions, so I can help you get the exact effect you're after:
  1. Are you going for a draw-in-then-erase-out sequence, or something more like both effects blended together?
  2. Is the path you're working with open or closed?
The good news is there's a more flexible option built for exactly this: path trim keyframes. Instead of relying on presets, you set keyframes for "Path trim start" and "Path trim end" independently, which lets you recreate draw and erase behavior (and combinations of the two) with full control over timing, and it works on both open and closed paths. Here's the doc that walks through both approaches: Animate strokes with path trim.
Give that a try and let us know if it gets you the result you're looking for.
djvSolution
meet
meetAuthor
Aug 4, 2026 3:09 AM UTC
Hi ​@djv here are the answers of the questions.
1. Yes I’m trying an effect like path draw first and then it gets erased out.
2. yes it is an open path.
I was able to draw-in-then-erase-out sequence with path trim keyframes but i thought it will be quick to create using the preset.
But thank you or the help. I appreciate it!
