Adel
Jun 11, 2025 11:06 AM UTC
Noise effect bug
Hi, I’m having a problem publishing a noise effect style I’ve created. Once I publish the library, everything else is able to publish aside from the noise effect (its status constantly shows ‘Added’). The error I get is this:
Is this a known problem? Anything I can do to get my noise effect to publish?
Thanks!
Celine_Solution
Jun 17, 2025 9:04 AM UTC
Hi everyone,
Good news — our engineering team has resolved the issue, and the style should now publish as expected.
​@Adel, I can see on our backend that you're now able to publish the noise effect successfully! 🙌🏻
For anyone else still experiencing issues, please try restarting the Figma app or refreshing Figma in your browser, then attempt to publish again.
Thank you everyone for your patience while our team worked on this!
Jun 11, 2025 2:22 PM UTC
Hi Adel, thanks for flagging this!
Could you start by checking the Review updates panel to see if there are any messages indicating an error or required updates? You can follow the steps in how to review updates.
Since identifying the root cause of the noise effect style issue is a bit tricky without accessing the file directly, we recommend reaching out to our support team so they can investigate further. You can submit a bug report here.
When filling out the form, please include:
  • A link directly to the affected file (tor hrough a link to that component)
  • Give ‘Edit’ access for support-share@figma.com on the file and any related libraries (there is no impact on your billing)
This will allow our team to properly test and investigate the issue. Just a heads-up: access at the team or project level is required for us to troubleshoot publishing issues effectively. Thank you!
O.G.
Jun 12, 2025 1:08 PM UTC
​@Adel We are having the same issue this morning. It is with noise effect only.
Jun 12, 2025 3:02 PM UTC
Hey ​@O.G. , thanks for your feedback — sorry to hear you’re running into this too. I just tested publishing a noise effect in my library and it seems to be working on my end.
Would you mind reaching out to support as mentioned below by filling out this form? Submit a bug report
Be sure to include a link to the affected file so the team can take a closer look and try to reproduce the issue. Thanks so much!  🙏🏼
O.G.
Jun 12, 2025 5:25 PM UTC
Hello ​@Celine_
After an hour or so of errors, it is now working. It gives the occasional error here and there, but all in all, it is good.
Adel
AdelAuthor
Jun 13, 2025 5:46 AM UTC
Thanks ​@Celine_ ! I’ve submitted a bug report.
Celine_Solution
Hi everyone,
