Emma26
Feb 26, 2026 3:00 PM UTC
No variables available
From this morning I’ve been unable to use variables, here’s what happens:
  1. On first load/reload of page
  2. Select Gap Dropdown
  3. Select Apply variable
  4. Variable list appears briefly then updates to “No variables available”
It’s not happening with Colors and is the case on every file I’ve worked on this morning.
All my variables should be available. Non are marked as “Hidden from publishing” and the scope is set to Gap.
Celine_Solution
Feb 26, 2026 3:55 PM UTC
Hey ​@Emma26 , thank you for sharing the screenshots and details, and sorry you’re running into issues with Variables!
This definitely looks unusual, and I’d like our Support team to take a closer look. I’ve gone ahead and created a ticket on your behalf so they can investigate further.
I’ve gone ahead and created a ticket on your behalf so they can investigate further with your email address: ekxxxgh@shxxxck.xom. For reference, your case number is #1766439. Please check your inbox when you can and free to reply directly to your case with any additional context, including the URL of the impacted file. Thank you!
Update: Our team has pushed a fix. Please refresh Figma and try again, thank you!
Celine_Solution
Probin Johori
Mar 2, 2026 6:49 AM UTC
We’re experiencing the same issue on our end. It’s also affecting the Variables panel when we try to update variable values, it shows “No variable found.”
We’ve already raised a support ticket for this (#1771100).
Is anyone else facing the same problem, or has found a workaround?
Mar 2, 2026 11:15 AM UTC
Hey ​@Probin Johori , , sorry to hear you’re running into trouble with Variables as well.
I’ve checked Emma’s case on our end and can confirm it’s been resolved. Our team has pushed a fix for this issue. Could you please refresh Figma and give it another try?
If you’re still seeing the problem after refreshing, please follow up on your existing support ticket so our Technical Quality team can take a closer look at it. They’ll be best equipped to investigate your case directly.
Svitlana
Mar 3, 2026 9:06 AM UTC
​@Celine_ hi! Our team has been experiencing the same issue since Friday. I’ve already reported it, but we haven’t received any updates.
Can you please assist us? We’ve restarted our laptops and refreshed Figma, but nothing has resolved the issue.
Mar 3, 2026 12:26 PM UTC
Hey ​@Svitlana , thank you for flagging this and sorry to hear the issue still persists! I’ve replied to you in this Forum topic, please have a look when you can, thanks.
Update here:  Our engineering team have found the root cause of the issue and released a fix for this.
For others who encounter similar issue, please refresh Figma and try again.
If the issue still happens, please submit a bug report by going to the Support Hub / Clicking Start a chat / Typing “Report a bug”  and including a direct file URL (with view access granted to support@figma.com). Thank you!
