Sam Nguyen
Apr 9, 2026 10:57 PM UTC
No export library button for Figma Make - Professional Plan
I have a full seat. I have created this library named KBC Bootstrap, which I’ve published and I don’t see the “Export to figma make” to create a Make kit for Figma Make. I’ve tried all of the suggestions. I can not figure out why I can’t see it. The option was available couple weeks ago.
Celyn_L
Apr 10, 2026 1:39 AM UTC
Hi @Sam Nguyen — Celyn from Figma Community Support here.
Thanks for flagging this and for sharing the context. I understand that you’re not seeing the “Export to Figma Make” option to create a Make kit — this may have been related to a recent bug that our Engineering team has released a fix for.
Could you try refreshing or restarting Figma to make sure you’re on the latest version, and then go through either of the flows again?
From a Design file:
  • Click the drop-down menu next to the file name
  • Click Library
  • Click Use Library in Make
  • Select one of the two options
From a Make file:
  • Open Settings in the upper-right corner
  • Select Create a kit
If the issue still persists, the next best step would be to submit a bug report so the team can take a closer look at your specific file.
You can do this via the Support Hub → Start a chat → type “Report a bug”.
After submitting a report, please:
  • Share a direct link to the impacted file within the ticket
  • Invite support-share@figma.com with “Can View” access (this won’t impact your billing and helps us reproduce the issue)
  • Include a full screen recording of the issue if possible
Thanks again for taking the time to flag this — we appreciate it 🙏
Sam Nguyen
Apr 10, 2026 3:16 AM UTC
Where is “Support Hub → Start a chat → type “Report a bug”. Share a link or a screenshot please. It is so frustrated already. I cannot find an option to report a bug.
Celyn_L
Apr 10, 2026 5:33 AM UTC
Hi @Sam Nguyen — I can see that you’ve already reached out via ticket #1841535, and I’ve gone ahead and escalated it internally to help increase visibility.
Please keep an eye on your inbox for the team’s follow-up, someone from the team will be in touch soon.
