Albbeson
Aug 14, 2026 6:58 AM UTC
New users can’t see all project files and folders despite having editing access
When I invite a new user to a Figma team and give them access to the entire project and its folders, the folder contents are not displayed consistently.
Some folders appear completely empty, while others only show some of the files. In some cases, all files are visible as expected. The user has editing access to the team/project, but they still cannot see all of the files and folders they should have access to.
As a workaround, I have to manually invite the user to individual folders again, even though they already have editing access at the team/project level.
Jaycee Lewis
Aug 31, 2026 5:25 PM UTC
Hi, ​@Lauri_Incrosnatu I updated the ticket to match your urgency. I also added additional notes and context for the agent. I’ll keep an eye on things until we see a resolution. — Jaycee
Rafael Grullón
Sep 1, 2026 6:53 AM UTC
We’re having the same issues described here; only the original Admin can see all the projects in a Folder, the rest of the team (even if part of the Who can Edit list) can not.
Gayani_S
Sep 1, 2026 8:41 AM UTC
Hey ​@Rafael Grullón, thanks for flagging this here!
What you're describing (only the original admin seeing everything in the folder, while teammates on the Who can Edit list still can't)  lines up with a few other reports in this thread. So I'd like to help narrow down what's going on for you specifically.
A couple of things worth checking first:
  1. Open the affected folder and click Share. At the top of that list, look at the Who has access row. Does it show your team or plan name, or does it say People invited to folder?
  2. If it says People invited to folder, that folder's access is limited to only the people listed directly on it. A teammate's team-level "Can edit" role won't extend to that folder automatically. They'd need to be added directly to that folder's share list (or the setting switched back to inherit from the team) to see it.
  3. If your teammates are already listed directly on that folder's share modal with Can edit and still can't see it.
For more on how folder-level access and inheritance work together, here's our guide to File and folder permissions.
Since checking the specific folder and accounts involved needs more than what I can see from the forum, I'd recommend opening a request through our Support Hub with a link to one of the affected folders. That'll let us dig into the account details and confirm whether this needs further investigation on our end.
Lauri_Incrosnatu
Sep 3, 2026 3:42 PM UTC
I took some time and collected three example folders from our own Figma environment that showcase the problem. This information has already been sent to support by email.
I've also simplified and anonymized them below for this forum, referencing the real examples, in the hope that it helps get this issue resolved even quicker. Even though these images are simplified, all three examples are real, taken from our own Figma.
New user "Jerry Seinfeld" added to the Acme Inc team from the admin panel. Has full edit rights and shows as "Member" in the confusing users list next to the team dropdown.
Example 1
  • Old project "folder," created years ago
  • Uses Figma's default access settings for both folders and files
  • In this specific folder, the new team member "Jerry Seinfeld" was automatically added to the collaborators list and can access all files inside this folder.
  • We did not need to do anything. Works the same as it used to when adding a new team member to our Figma.
Folder share view
Collaborators list includes the whole team, including the new user
Share file menu of an example file (using Figma’s defaults)
Example 2
  • New team member "Jerry Seinfeld" was NOT automatically added to the collaborators list and does NOT see any files inside this folder.
  • In folders like this, we've had to change each file permission from “People invited to file “ → “Acme Inc” one by one so that new team members will have access to the files.
Folder share view
Collaborator list missing the new user for some reason
Example 3
  • New folder, created after the Projects → Folders migration
  • Uses Figma's (new) default access settings for both folders and files
  • New user "Jerry Seinfeld" can automatically see and access all files.
Folder share view
I know this is a lot to process, but the key questions are:
  • Should new team members automatically appear on the collaborators list of old folders?
  • Why did the new team member appear in the collaborators list for Example 1, but not Example 2?
  • If you've changed the logic so that new members no longer appear in the collaborators list of old folders, and Figma's previous default permission on all the files inside our old folders has remained unchanged through the migration, how are we supposed to get new members access to all our old files, given there's no way to mass-edit permissions? We have hundreds of old folders and thousands of old files, and changing permissions one by one by hand isn't feasible.
StephenD
Oct 8, 2026 9:21 PM UTC
I am having the same issue as Lauri -- new users are not showing up in the Inherited Folder access list for certain files. We are on the Pro plan, and each folder is set to Anyone in the Team Can Edit. But they are missing certain files within, and their names don’t show up in that “People from __ Folder” layer.
I don’t have time to go through every file and change the top audience level. And doing so would cause some problems bc we have many files set to “Anyone with the link can view” so we could share with clients. In the past, that didn’t override anyone on the team from being able to edit.
I’ve read the resource link so many times but this feels way more confusing than it should be.
Donkt
Oct 9, 2026 2:32 PM UTC
Hi ​@StephenD! Thanks for posting.
The best way to get help with this will be to create a support ticket here including a link to the affected files/folders. We can’t investigate this through the forum, but the support team will be able to look into this more thoroughly for you.
You can do this by searching something like “folder access” into the search bar, scrolling down then clicking Start a chat.
If you need help with anything else please reach back out and we’ll see what we can do!
Lianne
Oct 13, 2026 9:25 AM UTC
I have the same problem, but also with users that were already added to our team. When creating a new folder + file usually everyone with edit (design & dev) can acces this file. But now when we create a new folder and even when it’s set to “everyone at {company name} can edit.” They have to be invited.
Donkt
Oct 13, 2026 11:08 AM UTC
Hi ​@Lianne!
We can’t investigate this through the forum, but if you could create a support ticket here and include a link to the affected folders/files our team can look into this for you.
Type something into the search bar, scroll down then click Start a chat to start the ticket creation process.
Let us know if you need help with anything else!
