JGJG
Oct 20, 2026 7:54 PM UTC
Nested component updates not propagating to existing instances
TL/DR: Nested components aren’t propagating updates correctly. Looking to debug or find a solution that avoids resetting the component instances.
I have a parent component that’s used across hundreds of frames, with a nested logo component sourced from a shared company library. When the company updates a logo variant in the master library, the nested logo in my parent component doesn’t update automatically.
Resetting the nested logo instance in the parent master fixes it there, but existing instances of the parent still show the old logo. Resetting each instance of the parent component makes the logo update, but also removes its custom dimensions, which I need to preserve. I also want to avoid manual resets, as these updates happen frequently. These assets are used across digital marketing assets with all different dimensions, so the instances appear at many different sizes & manually resetting across hundreds of assets would be extremely tedious.
Is there a way to propagate the updated nested logo component to all existing instances without resetting the component, especially without resetting the size dimensions / scale? (Also note: I’m looking for a native Figma solution without using 3P plugins)
adamsmasher
Oct 21, 2026 10:16 PM UTC
Thanks for your post, ​@JGJG. Resetting hundreds of assets would be a lot of work, especially when their sizes need to stay intact.
Are you customizing the dimensions of the nested logo, or of the parent component? I’m guessing it’s the logo in specific since that would explain why you need to reset it. One approach worth exploring is defining the logo’s resizing behavior in your parent main component, so you only need to resize the overall marketing asset.
For example, the logo could stay a consistent size and remain anchored to a corner, or adapt through an auto-layout container with its aspect ratio preserved. That could remove the need to adjust the nested logo individually and should let it and nested instances automatically receive logo updates.
JGJG
JGJGAuthor
Oct 23, 2026 5:23 PM UTC
Thanks for replying! Customizing the dimensions of the parent component, but it’s a fairly complex component with multiple frames, masks & the logos nested inside. I wanted to avoid creating variants of the parent component at various heights and instead control the height thru variables, but it seems variants might the best way to ensure it doesn’t break (since I can scale those manually to each height).
There doesn’t seem to be a way to reset the component instances without it reverting to it’s default dimensions. And no easy way to scale a complex component as a unit in the way it scales with K scaling tool.
adamsmasher
Oct 24, 2026 6:11 PM UTC
Thanks for clarifying that you’re resizing the parent, ​@JGJG - my previous suggestion won’t really change your basic issue.
Before you rebuild this with variants, could you share a simplified example with the parent main component and an affected resized instance? Ideally, include a newly created instance too, so we can compare how each responds to the same logo update. I’d like to create a ticket for you with our Technical Quality team for deeper investigation since it seems like the logo change should be propagating regardless of other layer changes.
