Hamed Moodi
Jul 21, 2026 3:11 PM UTC
Multi keyframe property in motion timeline
When i try to add key frame for existing position keyframe line, added another same propery in new keyfame line!
i try to add auto, property panel and timeline, but all way create extra propery in time line
    Jaycee Lewis
    Jul 21, 2026 7:28 PM UTC
    Hey hey ​@Hamed Moodi 👋 Thanks for flagging this!
    One important detail up front — when adding a second keyframe to an existing Position property, the intended flow is to:
    • Move the playhead to the new time
    • Change the X or Y value in the right sidebar
    • (Clicking Add keyframe a second time can sometimes create a separate track instead)
    When you have a minute, could you try this quick test?
    • Move the playhead to time zero and click Add keyframe on Position
    • Move the playhead to a later time (e.g., 1000 ms)
    • Change the X or Y value in the right sidebar—without clicking Add keyframe again
    That should connect a second keyframe on the same row. (Check out the Motion help center doc for a full breakdown.)
    If this still makes a duplicate track (or if you notice a second layer selected on the timeline), that’s something we need to dig into. A short screen recording showing your full timeline and layers panel would be super helpful.
    Thanks for testing this out 🤩 — Jaycee
