Jessie_Flores
May 7, 2026 7:02 PM UTC
Mouse Enter Flickering Glitch
I'm having a pretty serious issue with the mouse enter function in figma prototyping. It basically triggers over and over again instead of just once, creating a flicker. This is across ALL our prototypes (catastrophic for our workflow). It seems like it happens on transition from mouse enter to after delay.
Celyn_L
May 8, 2026 4:38 AM UTC
Hi ​@Jessie_Flores, Celyn from Figma Community Support here. Thanks for reaching out and sharing this context.
I understand you’re experiencing a flicker with the Mouse enter interaction in your prototype, I can see how disruptive that can be.
I saw that you’ve reached out via ticket #1890088, and the team is actively investigating this with you.
Thanks for working with the team on this, we’ll keep you updated there and help get things back on track as soon as possible 🙌
Apoorv Vekhande
May 13, 2026 11:43 PM UTC
I am facing similar issue with my figma prototype with Mouse Enter interaction
Jessie_Flores
May 13, 2026 11:48 PM UTC
I just wanted to bump this again as I have not seen any updates. This issue is also affecting all “after-delay” interactions. Thanks!
Celyn_L
May 14, 2026 6:44 AM UTC
Hi ​@Apoorv Vekhande, thanks for reporting this.
I understand you’re seeing the same issue with the mouse enter interaction, and I’ve gone ahead and created a support ticket so the team can take a closer look. Your ticket number is #1902148.
It would be really helpful if you could reply directly to the ticket with the following:
  • A quick screen recording showing the issue happening, with the full browser window visible
  • The affected file link, and please invite support-share@figma.com with “Can View” access. (this won’t impact your billing, and it’ll help us reproduce the issue and investigate further with Engineering).
Someone from the team will be reaching out soon, appreciate your patience in the meanwhile.
Celyn_L
May 14, 2026 6:56 AM UTC
Hi ​@Jessie_Flores, thanks for following up here and for sharing the additional context that this is also affecting all “after-delay” interactions - that’s really helpful.
I’ve taken a look at your ticket and can see it’s currently in progress. The team is actively investigating this with Engineering and will follow up with you directly on your ticket as soon as they have an update.
Thanks for sticking with us on this.
