Gayani_S
Jul 2, 2026 3:47 PM UTC
Hey ​@Iris Hofman, thanks for reaching out, and sorry for the trouble with your motion component set!
To help our team take a closer look, could you share a few more details:
  1. The URL of the main component, and the URL of the instance(s) that are looping instead of playing once
  2. Where the animation itself lives, on the main component, the instance, or a nested layer within the set
  3. Whether this happens in Design mode too, or only when you're working in Figma Motion
  4. Whether it happens every time, or just with this particular file
The screen recording and timeline screenshot you included are really helpful, thank you for that. If you're able to share the file directly, you can send it to support-share@figma.com with "Can view" access so we can dig in further on our end.
In the meantime, this article on using the Figma Motion timeline covers how playback settings (once, loop, ping-pong) are meant to work, in case it's a helpful reference while we look into this.
We'll follow up as soon as we hear back!
Iris Hofman
Jul 2, 2026 4:13 PM UTC
I think I've invited support-share@figma.com to the file with can view privileges.
This happens in present mode. In motion mode it works properly.
It happens in this file. I have not tried it in other files yet.
https://www.figma.com/design/y7TsMxeV7zAwg8iSDYWunj/HardwareInsight?node-id=3525-48016&t=z1SjfmeUH8WefeNW-4
Iris Hofman
Jul 3, 2026 8:37 AM UTC
The earlier link did not work. This is the link to the component:
adamsmasher
Jul 5, 2026 9:18 PM UTC
Thanks for sharing that, ​@Iris Hofman! Stepping in for ​@Gayani_S.
I can definitely see why this isn’t your expectation, and after checking with the team it looks like this is currently not supported. However, the good news is we are working on it! I don’t have an ETA or other information beyond that, though, so stay tuned and thank you for your patience. Let us know if you have more questions or run into other issues - cheers!
Iris Hofman
Jul 5, 2026 9:24 PM UTC
It would be nice to be able to read somewhere what the limitations are of this beta feature so that I know beforehand to not implement this feature in to my design system as I now spend time implementing it whilst it doesn't actually work properly yet with what I need it for.
adamsmasher
Jul 5, 2026 10:04 PM UTC
That’s understandable, ​@Iris Hofman, and I can see why it would be frustrating working toward something without knowing that there’s a limitation blocking you. It’s not quite the same as you’re asking, but the Figma Motion help articles show you what you can do, so if you don’t see something called out specifically there then you could take that into account. Hopefully this particular limitation is something we’ll have updated soon so you can see your work in action the way you intended it.
Dan Flynn
Nov 8, 2026 8:25 PM UTC
Hello ​@Iris Hofman, do you have an update on this Figma Motion looping issue within prototypes?
Just came here for the same issue and surprised this isn’t supported yet. Created an “Animate In” animation on a component variant and also set the motion playbar to “animate once”. However, when viewing the prototype, the animation for that variant continues to loop whenever that component variant is used.
