Vladimir14
Oct 15, 2026 2:01 PM UTC
Metric font displays incorrect when vertical trim is turned on
Hello,
In our company, we decided to use new text style specifically for buttons and similar components. This style has vertical trim set to “cap height to baseline”. All of a sudden, text’s line height gets squished:
I tried re-installing Metric font from several different sources but nothing helped. I’m currently on MacOS, on my private computer (PC/Windows 11) everything works fine. Thank you
adamsmasher
Oct 17, 2026 3:45 PM UTC
Thanks for your post, ​@Vladimir14. This is definitely unexpected, and interesting to note that you’re only seeing this in macOS.
Were you using the same font with the old text style, or did the switch to the new style include switching to Metric? Does this happen in both the desktop app and web browser, or just one? I wasn’t sure if this was a font uploaded to your org or account, or just one you’re using locally. I’ve seen similar issues before with certain fonts where the cap height is set shorter - it’s possible that Metric’s height is set to match lowercase letters.
One solution you could try in the meantime is setting the vertical trim back to Standard, provided it doesn’t affect your designs.
Vladimir14
Oct 19, 2026 6:54 PM UTC
Thanks for the reply, Adam. Yeah, on MacOS only (Sonoma 14.5) and on both web and desktop apps. I just can’t figure out why it keeps miscalculating the line height.
We were using the same font (Metric) with old text style previously (and actually, we still have both text styles but we’re using them for different components). New “trimmed” text styles are used only for components that have text content limited to a single row (buttons, tags, status etc.).
For now I’m forced to work with squished and painfully misaligned text labels because other designers in my team see these text styles normally. 🤷🏻
I don’t know man... if you find out something let me know. 🙂
Jaycee Lewis
Oct 19, 2026 10:44 PM UTC
Hey hey ​@Vladimir14 🤩 Picking this up for ​@adamsmasher 🙌
I opened a support ticket for this. The ID is 2207683 and the email subject line is Metric text bounds collapse with vertical trim on macOS. I added a few requests to the ticket for you so that support has what they need to dig in. Please keep an eye on your email (and spam folder if necessary) for the email and any replies from our team.
Thanks again for all your help so far! — Jaycee
Vladimir14
Nov 2, 2026 7:54 PM UTC
Hi, sorry for waiting. I put one affected component in this Figma file:
Let me know if you need more info. Thank you​​​​​​​
Vladimir14
Nov 2, 2026 7:55 PM UTC
I want to give you edit permissions but that option is greyed out… 🤷
ksn
Nov 2, 2026 9:52 PM UTC
Hey ​@Vladimir14 - sorry for the issues. I’m checking in on this -- can you first confirm you received an email from our Technical Quality team? It looks like a member of that team reached out to you via email on Friday. I’m going to include a link to the file you provided here, but it would be helpful if you could still share the demo file directly with the alias. It helps us do more investigation.
To properly share, you should be able to hit the ‘share’ button on the top right of the file → enter “support-share@figma.com” in the invitation box.
When you say it’s greyed out, do you not the option to send out the invite? I tried to see if I could replicate that, but the share seems to work. Can you verify you’re sharing to the full email and not just ‘support-share’?
Vladimir14
Nov 3, 2026 6:58 AM UTC
Hey KSN, I just sent an invite to the support. I had to remove existing file from my project to make some room and then move this file to it because otherwise Figma wouldn’t allow me to invite someone to the file (since I’m on free plan). Hope this helps
Vladimir14
Nov 3, 2026 6:59 AM UTC
Yeah, it was greyed out because I tried to invite someone while the file is in draft (instead of inside a project).
Best regards,
V.
