Miyuki Kaneko
Aug 8, 2026 8:56 AM UTC
MCPサーバーの連携について
スタータープランでClaude連携をしたいです。すると、MCPサーバーに接続できませんとなります。
Figma側で、「連携を有効にする」にアクティブにしようとすると、別ウィンドウが出て、有料プランへの切り替えが必要と表示されてしまいます。
月6回までは呼び出し可能ではないのですか?
    djvSolution
    Aug 11, 2026 4:37 PM UTC
    Hi ​@Miyuki Kaneko, thanks for reaching out!
    I understand the confusion here, but I think I know what’s happening. Please note that there are two versions of the Figma MCP server with different requirements:
    • Remote server: available on all seats and plans. On a Starter plan, you get 6 tool calls per month.
    • Desktop server: the toggle inside Dev Mode. This one requires a Dev or Full seat on a paid plan.
    The "Enable integration" toggle you were switching on is the desktop version, which is why you saw the upgrade prompt. Your 6 calls/month apply to the remote server, so you can skip the Figma toggle entirely and connect from the Claude side instead.
    Depending on which Claude you're using:
    • Claude Desktop / claude.ai: add the Figma connector and authorize your Figma account
    • Claude Code: run claude plugin install figma@claude-plugins-official, restart Claude Code, then /plugin → select figma → authorize (full instructions here)
    Once connected, right-click a layer in Figma → Copy link to selection, and paste that URL into Claude. Please know that the 6/month limit is counted against the plan that the file you're accessing belongs to. Hitting the cap can surface as a connection-style error, so that's worth ruling out too. Which Claude are you using: Desktop or Code? And if you can share the exact error text or a screenshot, we can investigate further.
    djvSolution
