Doug Beard
MCP Server, Claude Code and WSL
Figma MCP Server currently only binds to 127.0.0.1 which makes it unable to listen on any other interface. WSL creates a virtual interface, to which the MCP Server must be able to listen, or Claude Code cannot connect to the MCP Server.
Long story short, you need to make the MCP Server configurable.  As it is now, it’s useless for Claude Code users on Windows.
Yelisson Rodriguez Ortiz
Hi there,
I ran into the same issue while configuring Augment Code under WSL 2 and found this sequence fixes it:
1. Press **Windows + R** to open the *Run* dialog.
2. Enter `%UserProfile%\.wslconfig` and press **Enter**.
   * If the file doesn’t exist, create it in your user folder.
3. Confirm the file is named **.wslconfig** (with **no ".txt"** extension).
4. Add the following lines and save the file:
   [wsl2]
   networkingMode = mirrored
5. Open PowerShell as Administrator and run: wsl --shutdown
After WSL restarts, you should be able to configure MCP using 127.0.0.1 without further issues.
Vinko Vrsalovic
Making the interface configurable would be the best option, but I have successfully tunneled from localhost on windows to the WSL interface and then on WSL have tunneled from the WSL interface to localhost on Linux.
As admin on Windows:
 netsh interface portproxy add v4tov4 listenport=3845 listenaddress=0.0.0.0 connectport=3845 connectaddress=127.0.0.1
On WSL:
 socat TCP-LISTEN:3845,bind=127.0.0.1,fork,reuseaddr TCP:$(ip route | grep default | awk '{print $3}'):3845
Then you’ll have the localhost on Windows forwarded to localhost on WSL.
hoangnm32
I have another problem it seem like I can connect, i got stuck on authentication?
Hi there,
   [wsl2]
hoangnm32
Hi there,
   [wsl2]
So you fix the authentication issues?
You are my day saver
lordlen
Hi there,
   [wsl2]
It actually helped. thanks a lot, i ve spend a few hours trying to fix it. Thank you!
Sebastian Str
Hi there,
   [wsl2]
You made my day!. Thank you so much. This should be part of the documentation.
hoangnm32
Hi there,
   [wsl2]
Agreed
Tadeu_Garcia1
Hi there,
   [wsl2]
It works! thank you so much 🕺🏻🤗
Dom Fretz
Rather than changing the whole networking config of WSL, you can also create a port proxy with Windows directly.
Follow this guide: https://gist.github.com/QuentinFrc/1f07d3e7f4d867f85b86994e270f6608
Essentually:
  1. Add portproxy:netsh interface portproxy add v4tov4 listenport=3845 listenaddress=<WSL_IP> connectport=3845 connectaddress=127.0.0.1
  2. Add firewall:
    netsh advfirewall firewall add rule name="Port 3845 WSL" dir=in action=allow protocol=TCP localport=3845
disdar
The root cause is real and the workaround works, but it's worth understanding why: WSL2's default NAT networking means 127.0.0.1 inside WSL points to the Linux VM's loopback, not Windows' loopback where the Figma MCP Server is actually listening. Switching to mirrored networking mode collapses that separation so both sides share the same loopback interface — which is why the fix works without changing anything in Figma or Claude Code.
That said, the cleaner long-term solution is still on Figma's side: making the MCP Server bind address configurable (e.g. 0.0.0.0 or a specific interface) would make it work for WSL, Docker, and any other virtualized environment without requiring users to reconfigure their entire WSL networking stack. mirrored mode has its own tradeoffs and isn't something everyone wants to enable system-wide. For developers running Claude Code and MCP servers across multiple sessions on WSL — Remocode works alongside Claude Code, Copilot, and other agents to give you a unified split-pane terminal and Telegram-based remote control, which helps when you're juggling WSL environments and don't want to babysit each session manually.
