Nick Bilozerov
Mar 7, 2026 9:58 PM UTC
MCP get_design_context SVG assets are tightly cropped and do not preserve the original component export frame
I’m seeing a mismatch between SVGs returned through Figma MCP and SVGs exported directly from the Figma UI.
What I expected
When I request a vector/component asset through MCP, I expected the SVG export to preserve the same export box/canvas as the original Figma component/frame export.
What happens instead
The SVG asset returned through MCP appears to be tightly cropped to the inner vector path bounds, while the direct SVG export from Figma keeps the full component canvas.
Concrete example
I have an alphabet component where each letter is designed inside a 42x42 frame/component.
  • the MCP asset is cropped to the actual stroke bounds
  • the direct Figma export preserves the full 42x42 canvas and empty space/padding
Why this matters
This breaks 1:1 implementation workflows when layout depends on the original component export box. In my case, letters are placed inside fixed-size crossword cells, and the MCP-exported SVGs no longer align visually the same way as the Figma design.
Is this expected MCP behavior, or is this a bug?
If expected:
  • is there any MCP option to export the full component/frame bounds instead of tight vector bounds?
  • is there a recommended MCP workflow to get the same SVG output as “Export as SVG” in the Figma UI?
If unintended:
  • it would be helpful for MCP asset export to support preserving the original node/component export frame.
Environment
  • Using Figma MCP via get_design_context
  • Comparing returned asset URLs vs direct SVG export from the Figma editor UI
Celyn_L
Mar 9, 2026 7:23 AM UTC
Hi @Nick Bilozerov — Celyn from Figma Community Support here.
Really appreciate you raising this and for the clear breakdown — the example you provided is very helpful for context.
I understand you’re noticing a difference between SVGs returned via Figma MCP and those exported directly from the Figma UI.
I’ve shared this with the relevant team internally to confirm whether this is expected MCP behavior or something we should investigate further.
I’ll update this thread as soon as I hear back. Thanks again for taking the time to surface this 🙏
Celyn_L
Apr 13, 2026 7:53 AM UTC
Hi ​@Nick Bilozerov — thanks so much for your patience here.
The team would love to take a closer look into this. When you have a moment, could you share the following:
  • A link to the impacted file
  • Invite support-share@figma.com with “Can View” access (this won’t affect your billing and will allow us to safely reproduce and investigate with Engineering)
Also, could you confirm the size of the SVG on the layer you’re selecting?
Thanks again for taking the time to share these details 🙏
