IraX
Power Member
Mar 7, 2026 6:19 PM UTC
MCP get_design_context does not surface nested component variant props to parent
When using get_design_context on a parent component that contains and exposes a nested component instance’s property, the nested component's variant props are not surfaced in the parent's generated props. The nested component is inlined with only a className prop, regardless of what properties the nested component has.
Steps to reproduce
  1. Create a component with a boolean variant (e.g., ChildComponent with isActive: true | false)
  2. Create a parent component that nests an instance of ChildComponent
  3. Expose the properties from the nested ChildComponent
  4. Call get_design_context on the parent component set
Expected: Parent component props include a way to pass through the nested component's isActive prop, or the inline child function includes its variant props.
Actual: The inline ChildComponent function only accepts className. The isActive variant is visible in data-name attributes but not exposed as a prop.
ksn
Mar 19, 2026 8:27 PM UTC
Hey ​@IraX - I’m really sorry it took a while to get back to you, but I checked in with an engineer, and can you give me some info:
Can you share what url you’re passing to thru  get_design_context , and the exact output you get?
Starting on the surface, want to see if this involves code connected components or is related to design-to-react functionality.
