RonMan
Aug 8, 2024 6:04 PM UTC
Material theme builder disaster. Figma should test and approve significant plugins
Material theme builder version 20, released in May 2024, is not operational. The plugin generates theme colours but does not update them in any project files other than the original kit project. This means that if you had any work using Material 3 kit, you are not able to update the theme since May 2024. It is not possible to do any theme-related M3 work with a custom theme since May 2024. Themes in any project that people had done in Material3 UI Kit cannot be updated anymore since May 2024.
There is no other Material theme builder plugin. We are hostages of the situation.
There are tens, if not hundreds, of reports on the M3 DK page and on the Theme Builder itself page where it has been ignored since early 2024.
It appears that version 20 of the plugin was released untested, and the development team was immediately reassigned or disbanded. Nobody from the Material team reads bug reports; nobody responds.
Figma announced the category of UI kits but did nothing else; nobody tests anything that is in the plugin store. The provider uploaded a broken plugin that prevents people from working. Figma allowed this to happen. You have the resources, billions of dollars; couldn’t you assign a developer to fix the M3 Theme builder plugin?
And cue the answer “we will pass your feedback for consideration.” It is a disaster! It is not “feedback for consideration”.
Margo1
Oct 22, 2024 5:17 PM UTC
The Material Theme Builder was working well about a month ago but now when I put new colors in it only updates the Tonal Color Palettes and not the Light or Dark Theme colors. Is this the same problem that other people are having? Thanks so much.
Lisa_Taylor1
Nov 21, 2024 11:07 PM UTC
I have this problem too! My tonal palette colours are what I have input in the plug in but all variables are just total random colours- so basically the whole thing is completely unusable! Have you managed to get this solved?
Kevin_McGlone
Dec 18, 2024 6:43 PM UTC
I have also encountered this issue.
Colour changes are being applied inconsistently, As I am new to using this design system, I thought it was something I was missing. I was able to get tonal colours based on the colours I input.
If I want to change to the colours I want to use, is the workaround to go through all the colour variables and update them? Maybe on a component by component basis as I start to use them?
Stephanie20
Dec 31, 2024 1:24 AM UTC
I’m experiencing issues now as well. This plugin was working fine for me as of two weeks ago, then started bugging out on the 20th. I’m back online today after holiday break and it’s still giving me issues. It crashes my file, then when I reopen the plugin all my colors are wiped and I have to start building a new theme from scratch (even thought it has maintained the custom name I’ve provided for the theme).
It looks like someone has reported a similar issue in Git here: Plugin forgets colors after restart · Issue #361 · material-foundation/material-theme-builder · GitHub
Tamas_Bence_Gaspar
Jan 25, 2025 7:17 PM UTC
Still buggy and very slow
Why does it force to autoupdate tokens all time i change on the settings? really unusable :(
Nika6
Mar 23, 2025 9:27 PM UTC
I'm experiencing the exact same issue and haven't found a solution yet. Does anyone have any tips or workarounds? Manually inserting colors is crazy, especially with hundreds of them.
Alan_Gornick1
Apr 6, 2025 9:02 PM UTC
I’m having a problem with the theme builder that is breaking light and dark mode. A fresh download of the Material 3 Design Kit works perfectly. All modes are in order.
After running theme builder, the dark mode theme no longer works. If I go to a component like Text fields and swap the mode on the overall frame, there are some slight changes, but no dark mode.
Alan_Gornick1
Apr 6, 2025 11:03 PM UTC
After testing it again on a fresh library. It appears to be breaking the associations of the “M3 > sys > light” styles as well as all of the other styles. Out of the box, these styles point to the variables. After running the theme builder, the variable pointers get replaced with hex values, so the theme swap can no longer occur on things that had M3 styles on them.
The swap will work on objects that had variables assigned directly to them. Those are few and far between in the Material 3 library though.
Bê Santos
May 28, 2025 7:18 PM UTC
Hi guys, I'm having the same issue with switching themes. After updating the colors in Material Theme Builder, all the assets I've tested seem to lose connection with the custom M3 themes I just created. The only way to switch themes is by selecting a component and manually changing it in the plugin. The appearance option (from the right menu) doesn't work either. I have the professional plan, so 4 themes should work.
P.S.: all variables/colors are correct when I inspect the styles or variables panel. I really don't understand why this is happening.
If someone knows how can I achieve this theme switch (like happens in the material 3 design kit raw file), please help me.
Greetings from Brazil.
Bê Santos
May 28, 2025 8:59 PM UTC
I tried somethings after reading your post. Comparing the fresh new kit file with the one the theme builder plugin creates by updating the colors, I noticed that if you link all properties manually only in M3/sys/light the theme switch comes back to life \o/
Still super annoying doing that, but works. I noticed a little inconsistency in hovering components in dark mode. I submitted a bug report to Material team explaining all that. I hope they get in touch soon.
Thanks for sharing, Alan.
