Ankit Ujjwal
Jul 17, 2025 6:12 AM UTC
Manually edit a figma MAKE file?
I have created a figma MAKE file which requires some changes that can be done very easily manually. I am not able to find a way to edit the UI generated by figma MAKE file
    SergeantSass
    Jul 24, 2025 7:31 AM UTC
    I have the same question. I asked the Ai and in its reasoning tab I could see that it’s apparently not possible. This is what it said:
    “The user seems to have a misunderstanding about the workflow. Figma Make allows you to:
    1. Import designs FROM Figma
    2. Create interactive web applications based on those designs
    3. Export/save the web application code
    But it doesn't save back TO Figma as an editable design file. The character sheet they've created is a functional React web application, not a Figma design.
    I should clarify this for them and explain what their options actually are for preserving and working with this current version.”
    But then I ran out of prompts for the day, so it never actually answered my question
    SergeantSass
    Jul 24, 2025 9:23 AM UTC
    Turns out you can edit, but only the CSS code, which is cumbersome to say the least
    JayKay
    Jan 21, 2026 12:25 PM UTC
    Hi!
    I’ve created a website (for my thesis’s experiment), and it’s almost perfect. But I want to adjust something that would be done very easily manually. I’ve tried turning the Figma Make to Figma Design, but all the buttons are gone, and it became a static page with no interaction.
    How can I edit within Figma Make? I want to change the picture and some wording, and I don’t need AI for this.
