Asher Miller
Oct 19, 2026 5:14 PM UTC
Make File Environment Failure
I am having a problem with assets not loading in the Make file. After quite a few attempts at resolving the issue, it persists. I tried duplicating the project so it might have a new Make environment, but it still didn’t work. The app’s live bootstrap and cached-preview build both pass successfully, though.
New file URL:
https://www.figma.com/make/HXgQSuday11N9eipX0oARa/Interactive-Map-with-Features--Copy-
Failing endpoint:
https://www.figma.com/api/source/v1/make/environment/HXgQSuday11N9eipX0oARa?guid=0%3A6
HTTP response: 404
Jaycee Lewis
Oct 19, 2026 10:28 PM UTC
Hi, ​@Asher Miller 👋 Thanks for your detailed post. I have a few requests to help us get started:
  • Please share a screenshot or screen recording showing the assets failing to load and any errors you see
  • Add the SRID captured shortly after reproducing the issue
  • Share the exact steps that trigger the error. Does it happen when opening the Make file, loading the preview, or performing a specific action?
  • Does this happen only in this project and its duplicate, or are other/new Make files affected as well?
  • Which browser and version are you using? Have you tried another browser or an incognito window?
  • Were the assets loading correctly before? If so, approximately when did the issue start?
  • It would also help to know which types of assets aren't loading and whether they're missing from the editor, preview, or both.
Thank you! — Jaycee
