safii
Feb 15, 2026 9:54 AM UTC
Make AI
I created a website using Make AI and published it, but when I try to open it, it loads endlessly and eventually returns an error. What should I do?
Feb 16, 2026 3:49 PM UTC
Hi ​@safii , Celine from Figma here. Sorry you’re running into this. I can see you’ve already reached out to the Support team — thanks for doing that! Your ticket has been assigned to our Technical Quality team and they’ll be investigating the issue. For reference, your case number is #1747206. I’ve also added a follow-up note on my side.
In the meantime, you can try a few quick workarounds:
  • Open the site in an Incognito/private window
  • Click Refresh preview in Make, then republish
  • Duplicate the Figma Make file and publish from the copy to see if that helps
Thanks for your patience while the team looks into it.
Update: Our support team is waiting for your response to investigate it further. Please check your inbox when you can, thank you!
