Gayani_S
Gayani_SSolution
Oct 16, 2026 12:28 PM UTC
Hey ​@DesignQuery, thanks for reaching out!
Did any of your prototype links actually break, or did the agent just decline to move the sections?
Since you need every prototype link to stay intact, here’s how I’d move them yourself:
  1. Duplicate your file first so you have a safe copy to compare against.
  2. In the duplicate, select the three sections, right-click, and choose Move to page, then pick your Prototype page. We move layers to the same coordinates on the new page.
  3. Open the Prototype tab on the new page and check that each connection is still in place.
  4. If everything looks right, repeat the move in your original file.
Our Help Center articles cover the same ground. File and folder permissions has troubleshooting for people who can open a folder but can’t see the files inside, and the Starter plan overview explains how sharing works on that plan.
I’ll also share this with our team internally so they can see how the agent responded here. I’ll keep this thread open in case you have any updates.
Gayani_S
Gayani_SSolution
DesignQuery
Oct 16, 2026 2:54 PM UTC
Yes the all links between broke. I did step 1,2, 3 several times. and the links between different sections are lost. I requested agent to do this when I could not achieve this manually.
Tom Reem
Nov 3, 2026 4:40 PM UTC
Hi ​@DesignQuery, Tom here — checking in for Gayani today. Just to confirm, did the links between sections break when you tried moving them manually, or did another issue get in the way of what you were looking to archive?
If you’re still encountering this, a few details would help me follow up with the product team:
  • Did you select all three sections and move them together using Move to page, or move them separately?
  • After the move, were both ends of each broken connection on the destination page, or did some connected frames or sections remain on the original page?
  • Are the connection lines missing in the Prototype tab, do the interactions stop working when you play the prototype, or both?
A short recording showing the connections before and after the move would also help. If you’re comfortable sharing the affected file privately for investigation, let me know and I can help arrange that as well.
I’ll pass any additional insights along so the team has a more specific example to investigate. 🙏🏻
