Krystle Loh
Sep 10, 2026 11:56 AM UTC
Link issue
Hi, a couple of times inserted a color token, and after reloading the file, the color disappeared like this:
It’s suppose to look like this:
Is this a bug? how should i resolve this?
    Gayani_S
    Gayani_SSolution
    Sep 10, 2026 2:56 PM UTC
    Hey ​@Krystle Loh, thanks for reaching out!
    Thanks for the clear before/after screenshots. From what you're describing, the color you applied to that linked portion of text ("Electronics Verification") isn't showing up after the file reloads.
    Figma Design doesn't automatically color linked text, creating a link only adds an underline by default. Any custom color has to be applied separately as a Fill on that text selection, the same as any other text styling (more on that in Add links to text). Since the color goes missing specifically after a reload rather than right when you apply it, that points to the Fill not saving properly, rather than anything about the link itself.
    To help narrow this down, did you apply that color using a color style or variable, or pick it straight from the color picker as a one-off Fill? That'll tell us whether this is tied to a library style or more of a general save issue.
    A couple of things worth trying in the meantime:
    1. Reselect the "Electronics Verification" text, reapply the Fill, and reload the file once more to see if it holds.
    2. Try duplicating that text layer and check whether the duplicate keeps its color after a reload. <that'll tell us if it's isolated to that one layer or happening more broadly in the file.
    If it keeps happening, it'd help to have our customer support team take a look at the file directly. Feel free to open a ticket through the Support Hub, and you'll be able to attach the file there.
    Let me know what you find on the Fill type, and we'll go from there!
    Gayani_S
    Gayani_SSolution
    Krystle Loh
    Sep 11, 2026 8:47 AM UTC
    Hi, thanks for getting back. I tried both you suggested.
    1. Reselect the "Electronics Verification" text, reapply the Fill, and reload the file once more to see if it holds. When i applied on the same session, it works, but as soon as i reload, it disappears
    2. Try duplicating that text layer and check whether the duplicate keeps its color after a reload. <that'll tell us if it's isolated to that one layer or happening more broadly in the file. Still did not work after duplicating
    Gayani_S
    Sep 11, 2026 4:01 PM UTC
    Thanks for testing both of those and reporting back!
    Since the fill holds during the same session but disappears specifically after a reload, even on a duplicated layer. This points to something that'll need our customer support team to look at the file directly.
    Here's how to get that going:
    1. Head over to the Support Hub and select Report a bug as the topic.
    2. Include a link to the file with Can view access so the team can open it.
    3. Mention that it's the "Electronics Verification" text layer, the Fill disappears after reload (not right after applying), and it still happens on a duplicated layer too.
    4. A short screen recording showing the fill in place and then gone after reload will help a lot, if you're able to grab one.
    Once that's in, our team can dig into what's happening at the file level.
    Thank you,
    Gayani
