EliM
Mar 26, 2026 12:16 PM UTC
Limit of requests to Figma via mcp
Hi, I've encountered a problem: when I access Figma from my project through its mcp server, after a while I hit the request limit and am asked to wait 3-4 days. This happens despite me specifying which nodes to look for. How can I solve this problem? And how figma will fix it in the time of using different ai mcp’s
Mar 27, 2026 3:45 AM UTC
Hi ​@EliM,
I understand that you hit the limit while using the Figma MCP server.
The rate limits for the Figma MCP server are based on your Figma plan and seat type:
• Pro plan (Full seat): Up to 200 tool calls per day
• Starter plan: Up to 6 tool calls per month
These rate limits apply to Figma MCP server tools that read data from Figma, and unfortunately, we're unable to provide exceptions to these limits.
If you're consistently hitting the rate limits, we encourage you to slow down your requests.
You can find more detailed information here: Figma Developers > Figma MCP Server > Q&A > Plans, access, and permissions
After checking the linked developer documentation, if you believe you shouldn't be hitting these limits based on your usage patterns, could you please provide more details about what calls you're making and tools you're using when you get rate limited?
This information will help us connect you with the appropriate team to investigate further.
Court_Kizer
May 26, 2026 11:31 PM UTC
That’s just FALSE.
I log every single MCP call network. I’m on a pro plan, and was blocked after 2 TOTAL MCP calls for the entire month. I don’t use the AI or any other features.
I have strick logging and can prove it.
Figma MCP is useless. Moving to paper is the best option for now. Really disappointed in Figma. Those limits were added after the fact.
Nov 10, 2026 8:24 PM UTC
Also running into this issue.
Nov 11, 2026 8:35 AM UTC
Hey ​@Rachel Kern , Celine from the Figma Community Support team here, thanks for letting us know ! Please check my colleague’s explanation ​@Junko3  above and compare your plan and seat type with the current MCP rate limits.
One update to the earlier reply: Starter plans and View or Collab seats currently have a limit of 20 tool calls per month, rather than 6. The documentation also explains which upgrades provide higher limits.
If the limit you’re seeing doesn’t match your plan and seat, or you’re encountering a different error, please submit directly a bug report with your plan, seat type, MCP client, the tools you’re calling, and the exact error message—including the wait time shown. This will help our support team take a closer look. Thank you!
