Marie Guinot
Aug 29, 2025 8:04 AM UTC
Libraries: Variables not publishing (stuck in Hidden)
Hi everyone,
I created a library with color variables, but when I publish the library, my colors don’t get published – they only appear under Hidden.
  • They are not set as “Hidden from publishing,” so I don’t understand why they stay hidden.
  • If I create new colors, they also appear under Hidden.
  • I already tried duplicating my file, but the variables remain hidden.
  • Also, when I copy a component into another file, I don’t get the message “pasted with unpublished variables.”
I really don’t want to rebuild everything from scratch. Does anyone know what’s going on or how to fix this?
Thanks a lot for your help!
Marie Guinot
Marie GuinotSolution
Aug 29, 2025 8:19 AM UTC
Update / Solution
I actually found the solution 10 minutes after posting
I just renamed my variable collection (from “couleurs” to “colors”), and then everything worked fine!
Hopefully this helps someone else who runs into the same issue
Marie Guinot
Marie GuinotAuthorSolution
Update / Solution
Aug 29, 2025 1:48 PM UTC
Hey Marie, glad to hear you’ve found a fix and, thank you for sharing this workaround 🙏
It’ll surely help others facing the same issue!
Wirkkarl
Aug 31, 2025 2:43 PM UTC
Hi everyone,
Hey! I’ve run into similar issues with Figma libraries before — sometimes the variables just don’t publish correctly, and it’s super frustrating. One thing that helps me is keeping a clear log of what I’ve published and what’s still hidden, which I actually track in Phonexa for other projects. It’s not a direct fix, but having everything organized helps me spot patterns and avoid rebuilding from scratch. Hopefully someone here has a more Figma-specific workaround too!
