Gamaliel_Sierraalta
Oct 8, 2025 3:30 PM UTC
Layers panel doesn't show all my layers, they seem to be hidden.
I can’t see beyond a certain point in the Layers panel, the layers seem to be hidden by an invisible limit, which didn’t exist before the new update to the Layers panel. I can’t edit the layers because I can’t see them, and the focus interaction doesn’t work either.
Junko3Solution
Oct 17, 2025 3:54 AM UTC
Hi ​@Gamaliel_Sierraalta,
I understand that you’re having an issue with the Layers panel. From your screenshot, it looks like some layers that should appear in the lower half of the panel aren’t visible — is that correct?
I tested this on my end, and the Layers panel appears to be working as expected.
Could you please check a few things for us?
  • Is this happening only in a supported browser, in the desktop app, or in both?
  • Does this occur in a specific file or across all files?
Also, to cover the basics, please try these quick fixes and see if there’s any change:
  1. Close any Figma tabs you’re not using.
  2. Browser: Force-quit your browser and reopen Figma in a new window. Desktop app: Force-quit the Figma Desktop app and restart it.
If the issue persists, I recommend contacting our support team directly so they can investigate further: Submit a request
When submitting the form, please include:
  • The URL of the file where you’re seeing the issue, and grant edit access to support-share@figma.com (granting access will not affect your billing).
  • A video recording of the issue showing the full Figma screen.
  • Any findings from the troubleshooting steps above.
This information will help our team reproduce the issue and investigate it more effectively.
Junko3Solution
harrie
Oct 17, 2025 4:15 AM UTC
Quick fix for Figma layers not showing:
1. Expand all groups/folders– click the arrows/carets.
2. Check filters – set the search/filter to “All Layers.”
3. Check visibility – make sure the eye icon is on.
4. Scroll / resize panel – adjust the Layers panel height.
5. Restart Figma – reload the app or browser.
6. Select via canvas– click the layer on canvas to highlight it in the panel. These steps usually restore hidden layers.
Gamaliel_Sierraalta
Oct 17, 2025 12:41 PM UTC
​@Junko3 Maybe it was some kind of bug. I tried it on the desktop app, chrome, and safari and I got the same results. I even restarted a few times. After 24 hours or so, the issue was gone on its own.
​@harrie not at all what I needed.
Robert Lerry
Oct 24, 2025 3:23 PM UTC
Check if your layers are inside collapsed groups or if a filter is active in the Layers panel — that usually hides some layers.
