Zé Casal
Dec 15, 2025 10:36 PM UTC
Latest Figma update broke my components
The latest Figma update broke my components. Button hover states all messed up. Prototypes showing weird flickering.
Dec 16, 2025 10:39 PM UTC
Thanks for confirming, ​@Zé Casal!
Glad to hear. 😊
Dec 17, 2025 8:26 AM UTC
In our team it keeps happening, but with hovers in prototypes. Components we’ve been using this year that worked perfectly are showing hidden boolean items on hover and once you leave it keeps the booleans active.
Dec 17, 2025 5:27 PM UTC
Hi ​@Frida Ae, sorry to hear this!
When was the last time you refreshed your tabs? And are you using the latest version of Figma (125.10.8)?
The fix we pushed yesterday should have also fixed issues with hovers. Are you able to share a screen recording of what you’re seeing on your end?
With more information, we can send this back to the team to investigate.
Ravi Saxena
Dec 30, 2025 9:30 AM UTC
Hi Figma Team,
This issue is still not resolved.
When we update a component and publish changes from our design system file, the updated icon in the main design file resets to the default icon.
Example:
If we replace the component’s edit icon with a three-dot icon and make color changes, then publish the component, everything looks correct in the design system file. However, after updating the main design file, the three-dot icon reverts back to the edit icon.
Please help us resolve this issue.
Thank you.
Dec 30, 2025 10:41 AM UTC
Hey ​@Ravi Saxena , Celine from Figma here. I am working closely with ​@djv , happy to assist.
Thanks for following up and for sharing the details. As you are still having issues, to help us investigate this further, I’m going to send you a DM to gather some important information so our team can take a closer look at what’s happening. Please keep an eye out for my message. Thank you!
Hrishikesh Iyer
Jan 13, 2026 5:35 AM UTC
On Default State, I can see interactions for OnClick which is set for Hover Variant and not Default.
Hello Figma Team,
I am unsure if this is part of the same issue, but, I have been facing this with the toggle component, when trying to add different interactions for the different variants (States - Default, Hover, Disabled).
When hovering, the default changes to hover variant (this interaction is at the Parent component level) and at the instance, on hover I added a click interaction with a conditional action. (Bear in mind this is all for when the Toggle state is off).
Now when I try to add a click interaction for Hover (when Toggle State is On), I see that the Hover (Off) click interaction is visible. This is weird.
It seems as if the interaction is not getting applied to the state/variant but on the entire component. Not sure.
As this behavior I am seeing post the update and not before.
Can you assist?
Jan 14, 2026 1:24 PM UTC
Hi ​@Hrishikesh Iyer , thanks for the detailed explanation, that’s really helpful. From what you’re describing, this does sound like it could be a different issue, and it’s something we’d need to take a closer look at directly in the file to understand how the interactions are being applied at the component vs. variant level, especially if this behavior started after a recent update.
To investigate this properly, the best next step is to reach out to our support team so they can review your file in detail.
You can do that via our Support Hub here:
  1. Go to the Support Hub
  2. Type your question
  3. Click Start Chat, and type ‘Report a bug’ .The chatbot will help you open an email case with our Support team.
Once you’ve submitted the request, the team will be able to dig into the file and follow up with more specific guidance. Thanks again for flagging this!
David_Ortner
Jan 14, 2026 1:59 PM UTC
Today I have run into an issue that seems related to what was reported by Frida Ae. My component library is 2 years old and everything worked well up until now.
Currently however, when hovering over certain components in my prototypes they appear broken. It seems more or less random which components are affected. Some of the components change to states they should not, the label-text is lost while hovering or they randomly show elements like labels, helper text or icons that should not be visible per the defined boolean settings .This has not happened before. There were no updates made to the library in the past months that could be the reason for this behaivour.
What can I do to fix this? ​@Celine_
Jan 14, 2026 3:46 PM UTC
Hey @David_Ortner,  thanks for flagging this and sorry to hear you’re running into issues with your components as well.
Without looking directly at the file, it’s hard to determine the root cause. Since the issue originally reported by Frida dates back about a month and we didn’t receive further updates at the time — and given that it seems to have been resolved for some users — it would be helpful for our Support team to take a closer look at your specific case.
For anyone else still experiencing this issue, please submit a bug report so the team can investigate further and better understand what’s happening.
Please follow the steps I mentioned to reach out to our support team via the Support Hub here:
Thanks for your help! 🙏🏼
Update: For Ravi Saxena’s issue, I can see in the backend that it has been resolved on our side. Sharing the the temporary solution here in case it’s helpful for others: ‘Open your Actions menu in the file you're pasting to, using the keyboard shortcut Cmd or Ctrl + K, and typing "regenerate all instances slow," and hit enter.’
