uxlilly
Jan 5, 2026 8:05 PM UTC
Large file upload - Crash issue
I am trying to upload a large file (1GB+), but every time I try, Figma crashes. Unfortunately I am unable to see the file from its original location to edit the file and reduce the file size. Is there any way to fix this?
Jan 6, 2026 5:29 AM UTC
Hi ​@uxlilly,
I understand that Figma crashes when you try to upload a very large file (over 1GB).
Just to confirm, are you trying to import a Figma Design (.fig) file via the file browser? If so, please note that importing very large files (especially files over 1.5GB) can cause issues.
Here’s a related article: Guide to imports in Figma Design
The best option, if possible, is to access the original file and split it into multiple smaller Figma files, then import those files separately.
If you don’t have access to the original file, here are a few things you can try:
  • If you haven’t already, try importing the file using the Figma desktop app, which can sometimes handle large files more reliably.
  • If you mainly need the image assets, you can try renaming the .fig file to .zip and extracting it. You should be able to find the Images folder. I was also able to preview and save images by dragging files from that folder directly into a browser.
malavika krishna
May 18, 2026 1:28 PM UTC
Is there any other way to acces this file ​@Junko3 I am facing a similar issue while opening it on on the desktop app...But it still doesn’t open the file...
May 18, 2026 2:36 PM UTC
Hey ​@malavika krishna , Celine from Figma here, stepping in with Junko3 while she's away!  Sorry to hear the desktop app isn't working for you either.
Could you try the following:
  • Try opening the file in a browser or incognito window if that works, the issue may be specific to the desktop app. If you have access to the original file, the best long-term solution is to split it into smaller Figma files and import them separately as Junko3 mentioned.
  • Check on a different network or try temporarily disabling your VPN/proxy
If none of these help, please submit a bug report via our Support Hub so our team can investigate further. Go to the Support Hub / type "Report a bug" / click Start a chat, and when filling out the form please include:
  • The file URL
  • Your OS and desktop app version
  • A screenshot or screen recording of what happens when you try to open the file
If possible, please also grant “Can view” access to support-share@figma.com for investigation, thank you!
House
Jul 1, 2026 1:44 AM UTC
Same issue here. Trying to import a Jam file that is about 850megs. It crashes Figma every single time on multiple machines. The bug is reproducible on the desktop app and in the browser.
I am doing a big migration and I no longer have access to a cloud version that I can break into smaller files. I have a years of valuable work trapped behind this bug. PLEASE fix it. This is a bug that impacts your most engaged users.
amazonbizistech
Jul 1, 2026 4:53 AM UTC
I had a similar issue with a large design file. If Figma crashes before opening it, try accessing the file from Recent Files or Version History if it's stored in the cloud. If you can get it to open even briefly, duplicate the file first and then remove unused pages, images, or components to reduce its size. Clearing the Figma desktop app cache or opening the file in the browser can also help in some cases. I also came across a troubleshooting guide from Bizistech that recommended breaking very large projects into smaller files to improve stability, and that has worked well for me.
Celyn_L
Jul 1, 2026 7:16 AM UTC
Hi ​@House, thanks for taking the time to share this. I'm sorry to hear this is blocking your migration, especially with so much valuable work tied up in that FigJam file.
I've gone ahead and created a support ticket for you so the team can take a closer look and assist you directly from there. Your case number is #1991820.
When you have a chance, it would be really helpful if you could reply directly to the ticket with:
  • A link to the impacted file, and invite support-share@figma.com with “Can View” access (this won’t impact your billing and will allow us to reproduce the issue and investigate further with Engineering).
  • A screen recording showing the import attempt and the crash, if possible.
Someone from the team will be reaching out soon, so please keep an eye on your inbox. Appreciate your patience while the team investigates this.
Jami
Nov 9, 2026 3:46 PM UTC
It doesn’t work. I’ve tried Desktop version, web version, in incongnito mode everything. It’s the same crushed issue.
Jaycee Lewis
Nov 9, 2026 6:42 PM UTC
Hi ​@Jami Thanks for flagging.
Please submit a bug report via our Support Hub so our team can investigate further. Go to the Support Hub / type "Report a bug" / click Start a chat, and when filling out the form please include:
  • The file URL
Also please also grant “Can view” access to support-share@figma.com (this won’t affect your billing). Thank you! — Jaycee
Tim50
Aug 9, 2026 8:39 AM UTC
Same issue here!!!! Tried multiple files from 30mb to 2gb, from Figma desktop to browser... .everything is in loading mode, forever. Nothing is truly loading. What’s wrong??????? I need the files ASAP
adamsmasher
Aug 9, 2026 2:37 PM UTC
Thanks for your post, ​@Tim50. Sounds like you’re having a frustrating time uploading something to your design file. I’ve made a ticket with our Technical Quality team for you, which you should get via email shortly. I recommend replying to that with the following info:
  • A link to the Figma Design file shared with support-share@figma.com (this won’t affect your billing)
  • An example file that does not work for you (smaller is better if you are going to attach it to your email)
  • What browser and desktop app version you are using
  • What OS version and computer you are using
This information will be helpful to our team when troubleshooting with you - you can just reply to the email and include it.
Thank you for your patience!
