AhmedKhamis
Feb 10, 2026 8:18 PM UTC
issue with symbols
I have a problem when I try to use symbols — they appear in a distorted/broken form. I deleted the application and reinstalled it, but the same problem still exists. I also opened the website online and found the same issue there.
    djvSolution
    Feb 10, 2026 10:14 PM UTC
    Hi ​@AhmedKhamis, thanks for reaching out!
    It looks like you’re referring to the Symbols plugin. Is that correct?
    If so, plugins are managed by their creator. You can usually find the support contact listed on their Community resource page.
    For easy reference, please reach out to Symbols support via email at hi@linci.co for help.
    AhmedKhamis
    Feb 10, 2026 8:19 PM UTC
    Has anyone experienced this issue?
    djvSolution
    AhmedKhamis
    Feb 10, 2026 10:39 PM UTC
    ​@djv Hi
    Thank you so much for your quick response and guidance! I really appreciate your help.
    I’ll reach out to Symbols support as you suggested.
    GrevaGen
    Feb 14, 2026 8:53 AM UTC
    That distortion usually happens when there's a conflict with local fonts or a rendering glitch. If you’re using SF Symbols, try checking if you have multiple versions of the font installed on your system - that's a common culprit. Also, sometimes toggling 'Hardware Acceleration' in your browser settings (if you're on the web version) can fix the rendering issue instantly.
