Issue with Label Text Properties and Remote Library Color Variables
Hello Figma Support Team,
I'm experiencing an unexpected behavior in Figma related to Label text properties and color variables from a remote published library.
Issue description:
I'm working with a design system that uses atomic components connected to color variables from a remote published library.
I've noticed the following inconsistent behavior:
Changes to spacing properties are reflected correctly in the components.
Changes to color variables are not reflected as expected.
The issue appears in atomic components that use Label text properties.
I've verified that the latest library updates have been published and synchronized, but the color inconsistency persists.
I'm not sure whether this is related to Label text properties, nested component behavior, variable synchronization, or a potential Figma bug.
What I'd like help with:
Could you please investigate this behavior and help identify the root cause?
I'm happy to provide Viewer access to the design file so your team can inspect the components, variables, and their relationships directly.
Please let me know if you need any additional information, screenshots, or a screen recording to reproduce the issue.
Thank you for your help.
