Fayas
Feb 6, 2026 3:13 AM UTC
Issue with Google sheet sync
I’ve issue in syncing data from Google Sheet where the data is present in second or third tab. When I hit sync, the layer automatically hides itself and the data is not getting updated.
But this is not the case for the first tab.
Is this the known issue? should I keep 3 separate files to sync the data in Figma?
GrevaGen
Feb 6, 2026 6:39 AM UTC
Hey! I ran into this recently too. Have you double-checked that the Google Sheet sharing settings are set to 'Anyone with the link can view'? Sometimes if it’s restricted to just your organization, the plugin has a hard time fetching the data even if you're logged in.
bionic.violist
Feb 15, 2026 9:51 PM UTC
I just spent several hours trying to convince figma and a google sheet to talk to each other with Google Sheets Sync with no luck.  To answer the obvious:
  • yes - my google sheet is set to “anyone with link can view”
  • yes - all my layers start with a #
  • yes - all my layers are named precisely what the column is name, I did copy/paste
Fayas
FayasAuthor
Feb 16, 2026 2:08 AM UTC
For now, I’ve kept all the details in one sheet and synced with Figma.
