Rusu Daniela
Jun 3, 2026 8:17 PM UTC
Is it posible to lose the owner status over a project?
I’ve shared link to this project with a few people just to show my skills
like the project does not have onwer or admins. I can't change that. And I am not able to delete the project, but the link to it still works
have I been hacked?
what do I do?
Celyn_L
Jun 4, 2026 10:17 AM UTC
Hi ​@Rusu Daniela, Celyn from Figma Community Support here.
Thanks for reaching out here. I understand that you're concerned because your project appears to have no owner, you're unable to delete it, and you're not sure why it's still accessible through the link.
Just so I can make sure we're investigating this correctly, could you let me know if this is related to the issue you reported here?
https://forum.figma.com/report-a-problem-6/file-showing-as-another-user-s-drafts-but-i-m-the-creator-and-have-only-one-account-54531
If it's related to the same file or project, it may be helpful to continue the conversation on ticket #1942581, which I've created for you. This will help the team keep all the relevant context and updates together while they investigate.
If this is a separate issue affecting a different file or project, I can help to create another ticket for you so the team can take a closer look.
Happy to help either way, let me know!
Rusu Daniela
Jun 4, 2026 10:30 AM UTC
Yes, it is. I didn’t know how to delete this post :’)
Also, it might not be as much reletated as it could be but:
When I was still listed as the creator of the project and could edit it — I made a copy just in case. Until today I had no problems with the file's copy. Today I wanted to access the edit history in the file's copy, and that's when I lost the creator status on that file too. Now both files behave exactly the same way and have the same properties.
Celyn_L
Jun 16, 2026 5:21 AM UTC
Hi ​@Rusu Daniela, no worries at all - thanks for sharing that additional context about the copied file.
I took a look and can see that the issue has since been resolved through support ticket #1942581. I'm glad the team was able to help get everything sorted out.
Thanks again for taking the time to follow up here, and I hope you're all set now! 🙌
Rusu Daniela
Jun 16, 2026 7:54 AM UTC
Everything is set now thanks to your team's help
I am so thankful for your support
Have an amazing day 🫶🏻
