Janet_0
Oct 27, 2026 1:58 AM UTC
iPhone Duo "Open" preset is 890×626, but Apple's kit and App Store Connect point to 951×669
I noticed the new "iPhone Duo, Open" frame preset is 890×626, while Apple's official iOS 27 Figma UI Kit uses 951×669 (669×951 portrait). I dug into where the gap comes from.
- 890×626 matches the inner panel's physical resolution (1878×2670 px, from Apple's tech specs) divided by 3.
- App Store Connect, however, requires inner-display screenshots at 2853×2007 px, which works out to 951×669 pt @3x.
So it looks like iOS renders the inner display at 951×669 pt @3x and then scales it down to the panel, much like iPhone 8 Plus did. If that's right, designing on the 890×626 preset gives you a canvas about 6.9% smaller than what apps actually render at.
The "Closed" preset (466×678) lines up fine, because the outer display's screenshot size matches its panel (1398×2034).
For now I'm setting inner-display frames to 951×669 by hand. Has anyone checked this in the simulator or on a device? Would love to hear if you've seen something different.
Sources:
- https://www.apple.com/iphone-duo/specs/
- https://developer.apple.com/help/app-store-connect/reference/app-information/screenshot-specifications
Celine_Solution
Nov 10, 2026 10:30 AM UTC
Hi everyone! Good news, the product team has released a fix and updated the resolution! Please refresh your tabs to see the change.
Thanks again for flagging this and for your patience while the team worked on the fix!
alpennec
Oct 27, 2026 2:59 PM UTC
I posted this issue on X two days ago but I haven’t heard anything from someone at Figma: https://x.com/alpennec/status/2114410726479814937?s=20
I hope it’s fixed soon.
Oct 28, 2026 3:41 PM UTC
Hey ​@Janet_0 , thank you for your feedback! I’ve flagged it internally for investigation.
Thank you for your patience!
untitled
Oct 29, 2026 2:27 AM UTC
Update on this? This seems like a Figma mistake but considering how large the company is, it makes me feel like I could be wrong but Duo screenshots render at 2853x2007/3=951x669. This is causing confusion in our org
Nov 3, 2026 11:36 AM UTC
Thanks for sharing the dimensions and explaining the confusion this is causing in your org.
Yes, I can confirm that our team is currently working on a fix for the iPhone Duo sizing issue. We’ll share an update here as soon as we have more information. Thank you for your patience!
Celine_Solution
