Luongnd
Sep 24, 2024 7:11 AM UTC
Interactive state doesn't reset after overlay is closed
Yes I know this topic has been raised before, but I would like to raise it again, since it is breaking the core interaction in my design system. Is Figma even aware of this issue? Since the last discussion about it is ~2years ago, and this issue still exists.
Steps:
  • Create a Button component set with 2 variants: Default, On Press
  • Add interactions in the variant: “Default” → While pressing → Change to “On Press”
  • Insert an instance of the “Default” button into a new Frame
  • Add interactions to the button: On Click → Open overlay. Check the “Close when clicking outside” box.
  • Test the prototype
Results
  • When you click the button, the button change to “On Press”, the overlay opens, but when clicking outside the overlay to close it, the button does not reset back to “Default”.
Expected:
The button should reset to “Default”.
Gkotik
Sep 30, 2025 12:41 AM UTC
Please fix it, have the same problem
Giorgito
Oct 2, 2025 9:29 PM UTC
Same issue here, please do something!!
Airwrecka
Oct 9, 2025 12:29 PM UTC
I had to remove the interaction “while pressing” on our link component, because it stuck after opening and closing an overlay in our prototype. But good to know, I am not the problem...
Nicholas_Kaschak
Nov 5, 2025 6:33 PM UTC
Same issue here, posting for visibility!
Nov 5, 2025 8:09 PM UTC
Hey All, thank you so much for continuing to flag this issue and for your patience as we work through it.
I’ve shared this topic with our team, and they confirmed that it’s a known, long-standing bug they’ve been investigating since it was first reported back in January 2022.
While I don’t have a specific timeline to share at the moment, I completely understand how frustrating this has been—especially with more users running into the same problem recently. Please know that we’re doing our best to advocate for a fix and to keep this on the team’s radar.
Luongnd
LuongndAuthor
Nov 17, 2025 2:13 AM UTC
Thanks for letting us know. We look forward to the fix!
Designerd
Dec 19, 2025 11:45 PM UTC
Is there another method that the community can use to report this issue, other than forums? It seems that without a sustained, continued, press on the subject, it may not get addressed...
Lennard_Brauner
Feb 4, 2026 10:00 AM UTC
Please try this method:
Create a Component of the Button.
Prototype Button:
Default → Hover
While Hovering
Default → Pressed
While Pressing
Pressed → Default
After Delay: Change to Default.
Use an instance of it to oben the Overlay → Close clicking outsinde.
The Button Should be pressed as long as the overlay is opend.
After closing the delaytime begins and the button change to its default state.
For a larger design system, you might need to create an extra "Overlay Button" that automatically reverts to the default state.
Hope thats a usecase...
stevekulaga
Feb 11, 2026 4:53 PM UTC
Same. The hack that Lennard recommended does work, but it isn’t a great solution because there is still some interaction of the component that isn’t how it actually should be when being developed and could lead to confusion. Plus adding another interaction in a large design system isn’t ideal if it isn’t necessary. Please fix this Figma! 😩
Waldo
Feb 27, 2026 5:18 PM UTC
Fascinating topic, Google lists this thread for the exact problem. I’ve been two hours clicking prototype buttons, and this reveals I was not crazy nor doing something wrong.
It’s somewhat of a corner case, however, it is a bug
