Eric_H
May 2, 2026 4:52 AM UTC
In Figma Slides, I can't rearrange slide order.
Sometimes it works and sometimes it doesn’t, which makes me assume this is a glitch. When I try and drag and drop slides in the panel to rearrange the order, I’m unable to do so. Please help. Thank you.
    adamsmasher
    May 2, 2026 11:57 PM UTC
    Hey ​@Eric_H! Thanks so much for your post.
    From what you described it sounds like you are trying to drag panels in the sidebar on the left, correct? Are the panels you want to move grouped under a parent slide? I did a bit playing around with slides and noticed that I can’t always drag a nested slide. However, if I click a non-nested slide and drag it (I don’t actually need to move it anywhere, just drag it enough to see the horizontal blue line show) and then click and drag the nested slide it will work.
    It was actually a bit simpler to move slides around in Grid view, though that might just be me. Click the grid icon on the top left of the editor to switch to that view, then click and drag slides wherever you’d like. Grouped slides are a horizontal row, with the left-most slide being the parent slide. You can see an animated image of switching to grid view in the help article on organizing slides.
    Let me know if you still have trouble and we can go from there!
    nathanja
    May 4, 2026 2:19 AM UTC
    I am also encountering this bug, it’s really frustrating, and it also impacts the MacOS app which I downloaded to try to get around this issue.
    I might get one slide drag in before it stops working. And I find myself having to refresh the page and switching tabs to get the feature going again.
    It’s the left side-bar view of the slides. Can confirm gridview is a workaround for the problem but I find it a much less convenient interface.
    Eric_H
    Eric_HAuthor
    May 4, 2026 2:26 AM UTC
    Hi adamsmasher,
    My slides are not nested and I still can’t drag and drop them in the left panel when I’m not in the grid view. It looks like nathanja is also encountering this issue, which makes me think this is a bug.
    Todd Padwick
    May 4, 2026 10:18 AM UTC
    Yep me too. this is a new bug with the latest release. I have an urgent proposal to send out and it’s making it really tricky to work with.
    Jonas1
    May 4, 2026 11:51 AM UTC
    Same experience. I can’t rearrange the order of individual slides in the left thumbnail panel (Slide View). I’ve asked my colleagues, and they’re experiencing the same problem.
    If I go to Grid View, I can rearrange the slides.
    (MacOS 26.1, Native Figma app, updated)
    SBuser
    May 4, 2026 1:23 PM UTC
    Same problem (Mac OS 26.3.1. Figma Desktop App version 126.3.12
    please fix this bug
    Bruno_Cloutier
    May 4, 2026 2:15 PM UTC
    Same issue here. Can’t reorder slides by dragging/dropping in slide view in the Mac OS app, nested or not. Also, can’t seem to unnest some slides or create new groups/nests. Works in grid view though.
    Mack Trinh
    May 4, 2026 4:57 PM UTC
    Same issue. I'm using Arc on Macbook and Macmini. Both can't rearrange boards. Expect this might be Figma bugs. The only workaround is to switch to Grid View which I find not easy to work with.
    PaulUX
    May 4, 2026 5:13 PM UTC
    Same issue. Gridview is a workaround for now
    Jessalyn Lambert
    May 4, 2026 5:30 PM UTC
    Same problem, can no longer rearrange slides in the left column whether nested or not. Please fix this bug
