mohamad hosein
Jun 11, 2026 7:09 AM UTC
icon stroke size bug
I’m experiencing a bug with stroke widths on some icons in my file.
When I duplicate certain icons, their stroke width becomes smaller each time. For example, after duplicating an icon multiple times, the stroke visually keeps getting thinner and thinner.
I can manually correct the stroke width value, but after reloading the file, the stroke width goes back to the previous incorrect value.
The stroke width gets smaller with each duplication, and manual corrections do not persist after a file reload.
This seems to happen only with some icons, not all of them.
mohamad hosein
Jun 30, 2026 9:49 AM UTC
The latest update is that the Figma team has confirmed this is a bug and they are currently working on resolving it.
For now, the workaround is to select the affected instance, choose Reset instance, and then add the icon again. After doing this, the stroke weight should appear correctly and remain stable, even after duplicating the component or reloading the page.
Hope this helps anyone running into the same issue.
pierre designer
Sep 21, 2026 9:41 PM UTC
Hi ​@mohamad hosein ​@djv
Do you have an update regarding this bug? I’m encountering the same issue.
Many thanks!
