cobecreator
Sep 21, 2026 10:47 PM UTC
I only have 2 domains connected to my Professional plan, yet the system says I’ve reached the maximum limit and won't let me connect a domain to one of my main sites.
I'm currently subscribed to the Figma Professional plan.
According to Figma's official documentation, the Professional plan supports up to 10 custom domains shared between Figma Make and Figma Sites.
However, my account is currently showing that I've reached the maximum custom domain limit even though I only have 2 active custom domains connected across my Figma Make and Figma Sites projects.
I've already checked my existing and older projects and I don't have 10 domains connected.
Could you please check the custom domain allocation/count for my Professional workspace and remove any stale or incorrectly counted domain assignments?
Current active custom domains: 2
Plan: Professional
Expected limit: 10
This appears to be similar to other reports currently posted in the Figma Community.
This is already my second comment. I had submitted one before and received a reply, but I’m unable to view it. Whenever I click on it, the website says the page doesn’t exist.
Gayani_S
Gayani_SSolution
Sep 22, 2026 2:57 PM UTC
Hey ​@cobecreator, thanks for flagging this. I can see you’ve also been in touch with our Technical Quality team through Ticket #2144371.
A backend issue was causing some Professional plan accounts to see a "reached the maximum number of allowed domains" error even when they were well under their actual limit. That's exactly what happened here with your 2 connected domains. Nothing was wrong with your domain setup or count, and there's no cleanup needed on your end.
Our engineering team has since fixed this, so could you try connecting the domain to your site again? It should go through now.
As a reminder, Professional plans support up to 10 custom domains, shared between Figma Sites and Figma Make. You can find more on how that works in Manage a custom domain for your site.
If you try again and still hit the same error, reply here and we'll take another look right away. Thanks for your patience!
Gayani_S
Gayani_SSolution
