realphilamery
Apr 8, 2026 8:46 AM UTC
I need to deploy the backend function
Hi, I just got stuck with my app development and can’t exactly figure it out how to proceed without proceeding with worst and most tedious alternative option. I suppose the “Deploy” in my case does not relate to the Supabase Deploy button since that is obvious, I’ve been using it since I started developing my app, I had significant progress with my latest version 375 but didn’t encounter an issue similar to this one. I can’t find any “Sync Backend” button neither and no any experience with Supabase CLI. I might be missing something and would much appreciate if someone could assist me in solving this issue with a step-by-step guideline be it via Figma Make (if doable) or via Supabase or terminal as a last option.
Here are the details the last response from Figma Make:
“The root cause is confirmed: the /lorem/ipsums endpoint hasn't been deployed to your Supabase backend yet.
Here's what's happening:
  1. Your frontend calls /lorem/ipsums (line 311 in CompanyDashboardUpdated.tsx)
  2. The deployed backend doesn't have this endpoint
  3. The request somehow returns the response structure from /company/profile instead: {lorem: null, lorem1: null, lorem2: []}
To fix this, you need to deploy the backend function. In Figma Make, there should be a way to deploy or sync your backend changes. Look for:
  • A "Deploy" button in the Figma Make UI
  • A "Sync Backend" or "Update Functions" option
  • Or you may need to manually deploy using the Supabase CLI if Figma Make doesn't auto-deploy
If you have access to a terminal/command line, you can deploy with:
supabase functions deploy make-server-abcxyz123
Alternative temporary workaround: If deployment is complicated, I can modify the frontend to use the existing /lorem/deliveries endpoint instead, but this would require changing how the admin delivers matches to use delivery: keys instead of ipsum: keys. This is a bigger architectural change.
What needs to be deployed: The /lorem/ipsums endpoint code that starts at line 5527 in /tmp/sandbox/supabase/functions/server/index.tsx. This endpoint:
  • Fetches the lorem_user record to get the companyId
  • Queries all matches with prefix match:lorem:${loremId}:
  • Filters for status 'approved' (delivered matches)
  • Returns enriched match data with talent and role details
Once deployed, the debug logs I added will appear in your Supabase logs, and delivered candidates will display in your dashboard.
Can you check if Figma Make has a deployment option, or let me know if you need help with an alternative approach?”
AskDave
Apr 13, 2026 7:18 AM UTC
Hi Phil,
Dave here from Figma Community Support 👋
I am really sorry you’ve hit this snag, I can see how frustrating it must be when things don't work as expected. Thank you so much for taking the time to share all that detail with us, it genuinely helps us get a better handle on what’s going on.
After hearing back from my team they have said the following: the deploy button is exactly what they're looking for here. they can go to Make settings > Supabase > Deploy, as shown here “ Please try these steps and check the link
