yasinkara
Mar 7, 2026 8:49 PM UTC
I can't use 'point and edit'
I can’t send my changes in inline "edit with prompt", and the chat doesn’t see elements that I select.
the bug video
Mar 9, 2026 3:22 AM UTC
Hi ​@yasinkara,
I understand you’re having issues with Figma Make’s “Edit with prompt”. In your video, I can see that you’re requesting changes using the toolbar, but nothing happens.
To help us investigate further, could you please confirm:
  1. Does this happen in the desktop app, the browser, or both?
  2. Does the same issue occur in other Make files?
  3. If you describe the changes directly in the AI chat instead of using Point and edit, does it work?
Also, please note that Point and edit works with projects built using Tailwind CSS and shadcn/ui.
For more details and troubleshooting steps, please check the “Other issues” section in the “Troubleshoot in Figma Make” guide: Troubleshoot in Figma Make > Other issues
If you’ve tried all of the above and are still seeing the issue, please check your DMs. I’ll be sending you a message shortly.
