ondrejko
Jan 5, 2026 10:33 AM UTC
I can't login
Hi,
I wanted to sign-in with my work email today [redacted by forum moderator to remove PII] a I can't login. It's redirecting to some kiwi.okta sign up page. Check out this video please. I believe it's a bug since it worked before.
https://www.dropbox.com/scl/fi/q6ftayhe7upbpgk64b87h/Screen-Recording-2026-01-05-at-11.30.25.mov?rlkey=5uift94svo8k2x154cnj6118o&st=97mczmy8&dl=0
Gayani_S
Gayani_SSolution
Jan 5, 2026 1:32 PM UTC
Hey ​@ondrejko, thank you for sharing the screen recording! From what I’m seeing, it looks like Okta may be incorrectly routing the Figma sign-in to the Kiwi travel site.
To help narrow this down, could you try the following?
  • Check whether the same behaviour happens in an incognito browser mode.
  • Log out of Okta completely, then sign back in and try again.
  • If you’re using the Okta browser plugin, search for Figma within the plugin and try signing in directly from there.
You might also find this Okta support article helpful, as it describes a similar issue:
https://support.okta.com/help/s/article/okta-browser-plugin-detects-a-different-app-when-login-into-a-swa-app?language=en_US.
If this doesn’t resolve it, I’m more than happy to connect you with our support team so they can take a closer look.
Thank you for you help!
Gayani_S
Gayani_SSolution
ondrejko
ondrejkoAuthor
Jan 5, 2026 2:11 PM UTC
I'm not sure if I can help others if they have same issue, but I've tried in incognito window and it works. So I cleaned cookies and storages and it works. Not sure what it was, not using Okta at all.
Thanks for help!
