Claudia_Oliveira_CLEVER_FRANKE
Jun 29, 2026 10:22 AM UTC
How to publish a figma made tool with Organization?
The new feature to create plugins directly in figma is great, but I want to share these plugins/tools with my team but can’t find a way to do it. Plus, searching for it only leads me to the standard flow to publish plugins, which does not work for in-figma built tools.
So, how can I publish a figma made tool with Organization?
Gayani_S
Gayani_SSolution
Oct 5, 2026 12:14 PM UTC
Hey ​@nathalie.zimmermann, thanks for reaching out!
This is live now! As of September 1, you can publish internal generative plugins to your organization. Here's how:
  1. Open the file where your generative plugin lives.
  2. Go to the Tools tab in the left-hand navigation bar and find your plugin (tip: filter Source by Created by you to narrow things down).
  3. Click the ••• menu next to the plugin and select Publish.
  4. Choose Publish internally.
  5. Add an icon, name, and description, then click Publish.
Once it's published, anyone in your Organization can find it from the Tools tab, by opening the Source dropdown and filter to your Organization's name. Internal plugins don't need to go through a review process before they're available to use.
This is available on the Organization and Enterprise plans, so it's worth checking with your workspace admin if you're not sure which plan you're on.
For the full walkthrough, here's Create internal plugins for an organization.
Hope this helps!
Jun 29, 2026 11:29 AM UTC
Hey there, thanks for reaching out in the Figma Forum! To answer your question, publishing generative plugins privately to your Organization is planned for the coming months, stay tuned! 🙂
In the meantime, generative plugins live in your ‘Tools’ entry point in the Left Rail and are available across all your own design files. Please also note that if you run a plugin in a file and then share access to that file with others, they will be able to see your plugins when selecting layers where the tool has run.
Lolita Malaeva
Jun 30, 2026 9:06 AM UTC
Does that mean the tool is hosted locally and no one else in the team or organization can use it for now?
Esben Berg Aasgaard
Jun 30, 2026 11:18 AM UTC
Second this. Publishing to organization would be great.
Jon Quayle
Jul 1, 2026 8:25 AM UTC
Why was sharing these with your team not added as basic functionality, surely this is half the reason for creating plugins that fill use case for you and your team.
Jul 1, 2026 8:33 AM UTC
I have been able to share plugins with my team if they are working on the same file. But only, if built in that file!
Jul 1, 2026 9:26 AM UTC
Thanks everyone for the feedback and great questions!
To clarify, generative plugins aren't hosted locally on your machine. They're written and run directly inside your Figma file. They live in the root of the file and on the layers they edit or create. When you share the file, the generative plugin travels with it, so anyone with access to that file can use it there.
This is different from classic plugins, which are built locally using the Figma Desktop App and a development environment (such as VS Code or Cursor), and can then be published to the Figma Community for others to discover and use.
At the moment, there isn't a way to publish generative plugins privately across your Organization. As mentioned above, support for private Organization publishing is planned for the coming months.
Thanks again for sharing your feedback, I’ve shared internally to the team. It really helps us understand how you'd like to collaborate with these tools 🙂
nathalie.zimmermann
Oct 3, 2026 10:42 PM UTC
Any news on this? Would love to get an update as to when private publishing is possible.
Gayani_S
Gayani_SSolution
Hope this helps!
Oct 5, 2026 12:34 PM UTC
awesome! I don’t have the modal for Publish internally though. Neither a an area to filter just organization made tools.
