Cecily
Apr 7, 2021 11:57 PM UTC
Hovers on interactive components are malfunctioning and rendering oddly
Hovers on interactive components are malfunctioning in the prototype and present modes in a few different ways:
  • Rendering text oddly, letters are getting jumbled
  • Filling in areas with color
  • Seemingly disappearing from view
Seeing this on 2021-04-07T23:50:00Z
Niki_Cukier
Nov 8, 2022 7:22 AM UTC
Hey @dennsi can you send me your email so i can share with you a link ? So interesting thing is that now it actually works, but only after a few tries of hovering it… thats weird
Niki_Cukier
Nov 8, 2022 7:28 AM UTC
@dennsi Ok… actually i realized whats the delay…
I hove another component above it which also has a variant with “mouse enter” and with a delay of 10000ms. So now i realized that my second hover button only starts working when my compenent above it “closes” the “mouse enter” state!
Dont know if i am explaining it good 😅
Do you have any idea why this is happening ?
dennsi
Nov 8, 2022 8:37 AM UTC
Hey @Niki_Cukier I sent you a DM where you can provide me a link to the file.
First guess would be that often folks confuse while hovering with mouse enter
MJR
Jan 25, 2023 5:38 PM UTC
I was having the same issue and discovered having smart animation on the hover action caused the issue.
Once I switched the hover effect to instant the bug went away.
Denial_Keco
May 15, 2023 11:24 AM UTC
Hi, I can’t seem to get the hover working either.
I use instant always for hover and it doesn’t change.
Any idea what can it be besides nested components because I have a clean file with one newly created component so it should work but still no luck.
Deni
Jul 31, 2023 1:06 PM UTC
Hi, I had the same problem with flickering buttons and thought it was a bug, but actually it was my mistake 😀
I added “while hovering” interaction to both variants of the same component, which is wrong and causes this recursive loop. As soon as I removed “while hovering” interaction from the second (=“hover”) variant, the problem was solved. Maybe this helps someone 😊
GOMEZ_Tatiana
Oct 19, 2023 2:24 PM UTC
Hi, My hovering function is malfunctioning. When I hover it just moves to a different part of the screen (I am not making any mistakes) I do what I always do but now is not working property. Could I please get some help? 😦
GOMEZ_Tatiana
Oct 19, 2023 2:25 PM UTC
I tried the reset component state component state already but it this does not really appear if u are hovering
Nov 16, 2023 9:56 AM UTC
Hi, i had the same issue with a fixed componant, when i hover it, it bounce to initual position at the top and then go back to the fixed position (bottom of the screen in this case). For solving that, i just put the componant in an auto layout, fixed it and the issue was gone 😀 !
Sea
Jan 3, 2024 4:22 AM UTC
thank you, my problem has resolved because using your advice.
