DavidS
Jun 11, 2026 6:05 PM UTC
Help
J’ai un problème de mémoire qui rend le fichier “corrompu” ou inexploitable. Impossible à ouvrir.
Une personne de mon équipe m’alerte, fichier inaccessible. Ne peut pas l’ouvrir. J’’ai le fichier ouvert. Je copie et colle la moitié de mes fichier, soit 50% en se basant sur les informations à l’écran. Et je continu à travailler. Rapidement tout fini par planter. Depuis fichiers inaccessible. Solution ?
Jaycee Lewis
Jun 11, 2026 10:40 PM UTC
Hey  ​@DavidS — sorry you're dealing with this, that's a stressful one to hit mid-work.
Before we move to support, one thing worth trying that doesn't require the file to open:
  • From your file browser (dashboard, file closed), right-click the file thumbnail and choose Show version history
  • If a pre-crash version loads, duplicate that version (click the date → Duplicate) rather than Restore — that spins off a clean copy and leaves the original untouched, which is safer if the file is corrupted
  • Guide here
If the history view itself won't load, that points to a server-side issue our support team can look into directly. To get that moving, could you share:
  • Whether you're in the desktop app or browser, and your plan/team/seat
  • Whether the inaccessible file is your original or the copy you pasted into
That last one helps us know which file's history to check. Thanks!
— Jaycee
