Peter_Carleton1
Jul 13, 2026 1:16 PM UTC
'Go to main component' link missing when I right click on components instances
The ‘Go to main component’ link is missing when I right click on components instances in the lefthand menu.
I’m getting a smaller list of options, see attached image.
I’ve restarted my machine twice, and I’m an Enterprise admin so I have access to the design system file.
Can someone help with a fix, please?
    Tom Reem
    Jul 13, 2026 5:14 PM UTC
    Hey ​@Peter_Carleton1 — thanks for flagging this and for the screenshot.
    I see what you mean. What jumps out to me is that your whole right-click menu is short, not just the Go to main component link. A few things to check:
    1. Which mode are you in? Have a look at the toolbar at the bottom center of the canvas and confirm you're in Design mode (rather than Dev Mode, Motion, or Draw). Component navigation like this is available in Design mode, so switching back is the first thing I'd try.
      Design mode on toolbar
    2. Try right-clicking the instance directly on the canvas (not just in the layers panel) and let me know if the fuller menu appears.
    3. A few designers hit something similar, and the solution was often about where the file lives. As one member put it in this thread: “I was having this problem, no link to the master in the team library. But then realized the file I was working in was in the Drafts section. When I moved it into a team project where the library is, the links reappeared.” It's worth checking whether your working file is in Drafts rather than in the team project where the library exists.
    Please give those a try and let me know what you find — if the menu's still short in Design mode, we'll take a closer look at the file itself.
    Peter_Carleton1
    Jul 14, 2026 8:20 AM UTC
    I am in design mode and I’ve got to the bottom of it now.
    When I click on it first time I get the limited menu screen grabbed above, when I click a second time the full menu appears.
    Tom Reem
    Jul 15, 2026 6:21 PM UTC
    Hey ​@Peter_Carleton1 — appreciate you confirming, and glad you got to the bottom of it.
    That screen recording is very helpful. A single right-click on an instance in Design mode should bring up the full menu the first time. I tried to reproduce it on my end but couldn't get the same first-click/second-click pattern to occur.
    So I can pass along as much detail as possible to the team, would you mind sharing a few more things when you have a moment?
    1. Are you seeing this in the Figma Desktop App, a browser, or both? If it's the app, can you confirm there are no pending updates (I’m testing on version 126.6.14)?
    2. Does it happen in every file, or just this one? That'll help us tell whether it's file-specific.
    3. What operating system and device are you on, and does it still happen if you try on a different computer?
    Again, glad you're unblocked in the meantime and we'll keep an eye out for any further reports. 🙏🏻
    Peter_Carleton1
    Jul 16, 2026 8:57 AM UTC
    ​@Tom Reem Thanks for getting back to me.
    >>>I’m on 126.6.14
    >>>It’s happening in every file, I just double checked across 3 files. I reinstalled Figma and also logged into my work files from my personal Mac laptop and the same thing happens.
    >>I’m on a Mac laptop M3 Pro OS 26.5.2
    Tom Reem
    Jul 19, 2026 5:04 PM UTC
    Got it — and thanks for testing it that thoroughly, ​@Peter_Carleton1. The fact that it holds across three files, a reinstall, and a second Mac helps narrow things down. I've shared your report internally and we're taking a closer look.
    Appreciate your patience while we follow up.
    Tom Reem
    Jul 20, 2026 6:36 PM UTC
    Quick update:
    I checked in with the engineering team and they've identified the root cause. A fix is in the works, and we'll confirm here as soon as it goes live.
    Thanks again for taking the time to report this, ​@Peter_Carleton1!
    Peter_Carleton1
    Jul 21, 2026 8:01 AM UTC
    Quick update:
    Great, thank you for investigating.
    Pearse
    Jul 23, 2026 7:07 AM UTC
    Having the exact same issue as above. Looking forward to the solution!
    Peter_Carleton1
    Jul 23, 2026 9:00 AM UTC
    Just ran a Figma update and I’m still getting the same issue 😔
    Caro52
    Jul 23, 2026 2:55 PM UTC
    I’ve also been having the exact same issue. Will continue to check this thread for any updates!
